LED Beads
biferi
Joined Apr 14, 2017
531
Thanks for the help.
I like these a lot for projects I will be useing them for.
Does anybody know if they come longer say 6. Feet or 15 Feet things like this?
biferi
Joined Apr 14, 2017
531
That Link says it is for Neon Rope Lighting.
Neon is not LED and will this not be thicker then the Beads?
Ya’akov
Joined Jan 27, 2019
10,259
Those filaments are designed for use inside bulbs. They aren't designed to handle being... handled... and are easily damaged.
The size of the conductor would make 6 or 15ft lengths impractical. The LEDs current requirement exceeds the voltage drop / ampacity of the filament.
For the record, these are in no way "beads". That's Chinese English for individual emitters, these are COB filaments.
Jon Chandler
Joined Jun 12, 2008
1,615
For an up-to-date source of information, check out Adafruit's LED "nOOds". These noodles are a string of tiny LED elements encased in an extremely flexible silicone (probably?) tube about 3mm in diameter. They are exceeding bright with the flexibility of a cooked spaghetti noodle. The Adafruit page has videos showing how flexible they are and technical/tutorial information.
nOOds are not LED filaments designed to be used in LED bulbs nor are they LED "neon".
