Note that y=-2 does not only apply to x=0. It applies to any x.When c_3=0 in (3) , this means c is infinity which implies for (2) y=-2 when x=0, and for (1) the expression is undefined because y=infinity/infinity.
Also, the equation 1 is not undefined. Why would you say that? Generally, infinity/infinity is indeterminate, which simply means that you don't know what the value is. It can be any value depending on the details of what the expression actually is. Once you create a specific expression and take a limit, that expression can take on a meaningful value. In this case the limit is -2, meaning that the ratio itself is well defined, in the limit.
Equations 1, 2 and 3 are basically the same equation in different forms. Also, note that equation 3 has a defined meaning when c3 goes to infinity. Then you get y=2, just as you get y=2 for equation 1 when c=0.
If you are not ready for these concepts, that's fine, but I feel obligated to point out what I believe is the better interpretation of these confusing equations.
Tesla has a good point above. All this confusion can be avoided by taking his point of view, which seems reasonable to me. If you do want to go down the more difficult road, then you need to know the destination and work towards it, and not allow your own preconceived notions to divert you to some unknown land.
