MaxHeadRoom
- Joined Jul 18, 2013
- 30,808
You quote in your 1st post you have a one of these. https://www.omc-stepperonline.com/n...-0-03937-lead-length-100mm-8e11s0504sc5-100rsI've got another one coming - a small stepper motor with an 8mm lead length. If that doesn't work I might try a ball screw, and then possibly give up on attempting a threaded rod style actuator. The problem is the smaller you go with the thread and motor, the less likely it is to find a longer lead length. And ball screws are expensive!
What is the issue with the one you quote?
Lead screw:
POM (polyoxymethylene) nuts are known for their low friction and self-lubricating properties. They are commonly used in applications where high precision and low noise are required, such as in medical equipment and laboratory instruments. POM nuts also have good chemical resistance and can withstand high temperatures
