Hi everybody,
Sadly I'm unfamiliar with lead screws and need some advice. I need a linear actuator that when free wheeling offers very little resistance.
Current parts:
NEMA 8 lead screw
Rod: 3.5mm dia, 1mm lead
Length of rod: 100mm
(Parts exactly as shown in the link above)
I have already ordered parts as a test, but they're still in shipping.
USE:
While the stepper motor is off/freewheeling, the user should be able to slide the lead screw back and forward quickly with very little resistance (ideally with one finger). Assume a high quality bearing at the end of the rod. Assume no other outside resistance in the mechanics.
From my research, ball screws provide more noise and higher resistance compared to lead screws - am I correct about this?
If I'm wrong and the parts above would provide medium to high resistance, do you see another scenario that uses a lead screw style linear actuator?
Thank you for your time.
Current parts:
NEMA 8 lead screw
USE:
