LDR circuit causing Relay chatter
coderatlarge
Joined Jan 11, 2021
I have a LDR board that has been connected to a 5v electromechanical relay board through a Digital Out pin. Both the LDR board and relay board are connected by the Digital Out pin going from LDR to relay. When the light is really low, this works very well but when the light is just fading (dusk), it creates a relay chatter till the light becomes low enough. How do I solve this? Is capacitor a solution?
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC.
The term for what you need is call "hysteresis" (https://en.wikipedia.org/wiki/Hysteresis). That is, when the light gets low enough that it turns off, it takes a significantly brighter lighter to turn it back on and visa versa.
Comparators can be set to do that. There are lots of resources for how to do that. Here is one: http://rohmfs.rohm.com/en/products/...mp_linear/comparator/gpl_cmp_hysteresis-e.pdf
If you are using an MCU, it can also be done in firmware or simply add a delay function. For example, when the light gets low enough to first turn it off or on, require that level or lower to be maintained for some period, e.g., 3 minutes, before it turns off/on.
dl324
Joined Mar 30, 2015
17,224
Welcome to AAC!
You'll get better results if you used an analog input to read the LDR voltage and add some hysteresis in software.
Schematics and/or block diagrams are preferred to verbal descriptions of circuits.
