LCD screen with 2 oval areas of dead pixels on fishfinder
sdowney717
Joined Jul 18, 2012
805
Simply just happened. 2 smallish areas of the screen stay gray.
This is my Eagle fisheasy 350c color screen.
Has the screen lost connections internally to a ribbon cable?
Is the screen repairable by disassembly?
Everything else still functions .
Fishfinder is out of the weather, never gets wet in the boat cabin
MaxHeadRoom
Joined Jul 18, 2013
30,881
If it is a permanent area of the screen stays dead, I would say it is in the liquid crystal, I have experienced it on the TFT 10.1 screens I used to use.
Max.
sdowney717
Joined Jul 18, 2012
805
I think this is a TFT type screen?
It is not a touch screen.
When unit is off, background color is dark like black.
The dead area is light gray when it turns on.
One high up left side, one low down left side, roughly ovalish in shape.
Looking close in, I can see live working colored pixel dots next to the gray ones.
MaxHeadRoom
Joined Jul 18, 2013
30,881
It still sounds to me as though it is not something externally produced electronically, but a phenomenon occurring in the liquid crystal.
I could be wrong.:oops:
Max.
atferrari
Joined Jan 6, 2004
5,031
My camera exhibited a similar failure. I concluded it was caused by carrying it in my chest pockets. Intensive sweating, I am convinced, was the cause. Those spots kept becoming bigger and bigger. Had to ditch the camera.
38,938
The nature of the display design means that an electronic failure would give square/rectangular areas of dead pixels.
Round/oval areas mean it's the display itself that has failed and likely can only be repaired by replacing the screen. :(
MaxHeadRoom
Joined Jul 18, 2013
30,881
I have seen similar instances of damage where a TTF screen is used on a machine and an operator blows the machine off with a compressed air line.
Max.
sdowney717
Joined Jul 18, 2012
805
I can actually see that it is producing a proper image, as part of the light gray color.
So it sort of is working,
I wonder will it get worse, still no hope?
