LCD Display of my multieffects issue (lines)
hide24
Joined Jul 9, 2019
84
I have a guitar multieffect POD XT which it's LCD display seems not working.
I tried to open and check, and the display seems normal soldered to the PCB board.
Anyone knows what can be the cause to see only those lines?
Thank you very much.
twohats
Joined Oct 28, 2015
621
Have you tried finger pressure on the display?
You could go over the PBC with a stiff bristle paintbrush, the unit needs to be switched on in both cases.
The display is probably quite fragile.
Please keep us informed of your progress.
Good luck......
Dodgydave
Joined Jun 22, 2012
11,395
There's a row of pins in a Black socket underneath the display, what is that for i would give that a fiddle and see what happens..
