Hello,guys I have a code for LC meter using nokia 3310 display and PIC16F876A microcontroller using MPLAB . Which is written by some other person.
I want to know the function of following instructions
1. relay_tris();
2. RBPU = 0; // enable portB internal pullup
3. NOP();
I am using mikroC pro for pic. My question is how can i translate those highlighted lines from MPLAB to mikroc pro??
also what is internal pull up??and how i can apply internal pullup in mikroC??
Code:
#include "main.h"
#include "lcd3310.h"
#include "display.h"
void main(void)
int i;
initialize();
lcd_gotoxy(0,0);
//show startup logo
for(i=0; i<504; i++) lcd_send(logo_image[I], LCD_TDATA);
lcd_gotoxy(40,5);
lcd_puts("YUS'09");
delay10ms(200);
calibrate();
lcd_clear();
while(1)
if(LC_select) measure_capacitance();
else measure_inductance();
indicator(1);
delay10ms(30);
indicator(0);
delay10ms(20);
void initialize(void)
//setup comparator
CMCON = 0b00000101;
TRISA = 0b11001111;
//setup timer0 for frequency counter
T0CS = 1; //Transition on T0CKI pin
T0SE = 1; //Increment on high-to-low transition on T0CKI pin
PSA = 0; //Prescaler is assigned to the Timer0 module
PS2 = 1; //PS2S0 -> Prescaler Rate = divide by 256
PS1 = 1;
PS0 = 1;
//initialize 3310 lcd
lcd_init();
lcd_clear();
//others
lc_tris();
[B][COLOR=#ff0000]relay_tris();[/COLOR][/B]
[B][COLOR=#ff0000]RBPU = 0; [/COLOR][/B] // enable portB internal pullup
unsigned int measure_freq(void) //16-bit freq
unsigned int oldTMR0, prescaler_cntr;
TMR0IF = 0; //clear timer0 interrupt flag
TRISA4 = 0; //Enable RA4 output to T0CKI
delay10ms(2); //stablize oscillator
TMR0 = 0x00; //reset timer0 counter (including prescaler)
delay10ms(10);
TRISA4 = 1; //Disable RA4 output to T0CKI
oldTMR0 = TMR0;
prescaler_cntr=0;
do{ //self-clocking
T0SE = 1;
[B][COLOR=#ff0000]NOP(); NOP();[/COLOR][/B]
T0SE = 0;
prescaler_cntr++; // count until TMR0 incremented
}while(oldTMR0==TMR0 && prescaler_cntr<=255); //test if timer0 has incremented
//}while(oldTMR0==TMR0); //test if timer0 has incremented
return ((oldTMR0<<8) + (256-prescaler_cntr));
void calibrate(void)
unsigned char i;
lcd_clear();
lcd_gotoxy(1,1);
lcd_puts("Calibrating.");
lcd_gotoxy(1,3);
lcd_puts("please wait..");
remove_ccal();
F1 = (double)measure_freq(); //dummy reading to stabilize oscillator
delay10ms(50);
add_ccal();
F2 = (double)measure_freq(); //dummy reading to stabilize oscillator
delay10ms(50);
remove_ccal();
lcd_gotoxy(0,4);
for(i=0; i<84; i++)
{ //show progress bar
lcd_send(0xfc, LCD_TDATA);
delay10ms(2);
void measure_capacitance()
unsigned int var;
double Cin;
lcd_gotoxy(7,5);
lcd_puts(" capacitance");
var = measure_freq();
F3 = (double)var;
if(F3>F1) F3 = F1; //max freq is F1;
Cin = F2*F2*(F1*F1 - F3*F3)*Ccal/(F3*F3*(F1*F1-F2*F2));
if(Cin>999)
if(Cin>(999E3))
if(Cin>(999E6))
Cin = Cin / (1E9);
display_unit(4); //"mF"
else
Cin = Cin / (1E6);
display_unit(5); //"uF"
else
Cin = Cin/1E3;
display_unit(6); //"nF"
else display_unit(7); //"pF"
Cin = Cin*100; //scale to 2 decimal place
var = (unsigned int)Cin;
display_reading(var);
void measure_inductance()
unsigned int var;
double Lin, numerator, denominator;
lcd_gotoxy(7,5);
lcd_puts(" inductance ");
F3 = (double)var;
numerator = ((F1*F1)-(F3*F3)) * ((F1*F1)-(F2-F2)) * (gate_period*gate_period);
denominator = 4*pi*pi*F1*F1*F2*F2*F3*F3*Ccal;
Lin = (numerator/denominator) * 1E15; //scale to nH { pF/1E12 * nH/1E9 * (s/1E3)^2 }
if(Lin>999)
if(Lin>(999E3))
if(Lin>(999E6))
Lin = Lin / (1E9);
display_unit(0); //"H"
else
Lin = Lin / (1E6);
display_unit(1); //"mH"
else
Lin = Lin/1E3;
display_unit(2); //"uH"
else display_unit(3); //"nH"
Lin = Lin*100; //scale to 2 decimal place
var = (unsigned int)Lin;
void delay10ms(unsigned int period_10ms)
do{ __delay_ms(10); }while(--period_10ms);
}[/I]
1. relay_tris();
3. NOP();
