I’m designing a submersible heater that is controlled by an SSR and I need to add a mechanical safety relay. I would like this relay to latch off once triggered, so that it requires a power cycle to turn on again. I am using an op-amp comparator as the controller and simply have a diode feeding back into the non-inverting input to serve as a latch. My question is, will the circuit even turn on? Doesn’t the initial low state of the op-amp turn itself off immediately? This seems to work in my simulator.
Port 1 is state output to the microcontrolle.
Port 2 is a control line from microcontroller.
The op amp is an L272AM, which is good for 700ma.
Are there any glaring issues with the design?
