Laplace Transform question
Slaven Smiljanic
Joined Oct 24, 2018
5
Hey.
I have this circuit(attachment). I have to find output voltage.
I'm not sure how to determine initial conditions. Are it zero? And what is the general procedure in case of these problems?
LvW
Joined Jun 13, 2013
2,038
Why do you think, that the task should be solved based on the Laplace transform?
The input signal is a time-dependent voltage and the task is to find the ouput voltage - also in the time domain...
EDIT (some hours later): As you can see from Danas answer: You need the inverse Laplace transform.
