This is my ladder logic
Circuit operation of my circuit
When Input switch_1 is turned on , after 1 second , Output_1 is turned on.Then Output_2 is turned on at 2second and Output_1 is off. Then at 3 seconds , output_2 is turned off. Lastly , the circuit operation repeats itself. 1-->2-->1-->2-->1-->2
What I need to do.
For example , when input Switch_2 is turned on at output_2 is turned on , it will hold at output_2(meaning pause at that point) and when the input switch_2 is turned off , the circuit operation continue itself again. meaning 1-->2-->1-->2-->1-->2
If you don't get what I mean , it is something like this 1-->2(Hold at this point)-->1-->2-->1-->2.
When the input switch_2 is turned off ,the it goes from 2-->1-->2-->1-->2
Please help
Rich (BB code):
|--Input Switch_1 ---Normally closed T3----Timer_T1(1second)--|
|--Normally open T1---Timer_T2(2second)--|
|--Normally open T2-- Timer_T3(3second)--|
|--Normally open T1--Normally closed T2---Output_1--|
|--Normally open T2--Normally close T3---Output_2--|
What I need to do.
Please help
