Labels
biferi
Joined Apr 14, 2017
531
I have LibreOffice Writer and Avery Labels.
On the Avery Label Sheet it says 5161 so I can look it up in LibreOffice Writer.
So I go to File New Lables and click on this.
Then I put a Dot in Address Labels.
Now on the Right Side I click the Dropdown List to pick my Label Type and I pick Avery4. I do not know what other Avery I should pick.
Then the Dropdown List under it you pick the Label Number I can not see 5161 in the list.
Just to let you know my Label Sheet has 9. Address Labels on the Left Side and the Right Side.
Am I looking up my wrong Avery Type in LibreOffice Writer?
Should I not pick Avery4. what do I do?
sagor
Joined Mar 10, 2019
1,050
5161 only shows up if you pick Avery Letter size. The A4 size is a different set of labels. Make sure you are picking the right size of "paper"
You can also try File, New, Labels (or Business Cards), but that is more for importing from some database. Business Cards comes up with a similar selection
biferi
Joined Apr 14, 2017
531
Thank you for getting back to me.
As I was siting around I thought I would go throught them and I found it.
I do not know if you can help me with this part but I will ask?
The Label Sheet has 9. Labels on the Left and 9. Labels on the Right.
If I fill all the Labels and want to Ad another Sheet I know I can do a Page Break.
The thing is the next Page it puts after the First Page is just a Blank Page not a Label Sheet.
What am I not doing Right?
Thanks for all the help.
