I assume the batteries are in series, so the typical battery life would be 2200mAh / 4.3mA = 511 hours or 21 days.Thanks
How long would 2 x 2200mAh 18650's last with the L7805 sitting idle, no load?
I think I might have to put the batteries in parallel, I want to use 4 x 18650's that'll = 16 ish volts then Ive got to drop that back down to 5v so large heat sink and lost energyI assume the batteries are in series, so the typical battery life would be 2200mAh / 4.3mA = 511 hours or 21 days.
If that's not sufficient, could you add a circuit to remove the power to the L7805 when there's no output load?
Alternately there are very low quiescent power (microamps), low-dropout 5V regulators that likely would work for you.
What's the maximum 5V load current when the circuit is active?
That's if they are in series, not parallel.I think I might have to put the batteries in parallel, I want to use 4 x 18650's that'll = 16 ish volts
