L and R function in the vicinity of a SMPS output
abdulbadii
Joined Aug 30, 2017
91
What is the Inductor L and Resistor R function in a SMPS output vicinity below after transormer T output ?
What are the two values supposed to be calculated with respect to each other and to the two capacitors i.e. C1 and C2||C3 ?
Please help elaborate the real mechanism crystal clearly !
Danko
Joined Nov 22, 2017
2,256
Check links: https://resources.altium.com/p/switching-power-supply-output-filter-design-and-simulation
https://forum.allaboutcircuits.com/threads/smps-bleeder-resistor.103086/post-778364
And see PDF:
