KVL orientation question
Transatlantic
Joined Feb 6, 2014
44
I was following an example that was using KVL to calculate the Voltage across A/B.
The way they did it was to assume the current was flowing like this :
Vr1 = 4.5v (using the R1/R2 divider)
Vr3 = 13.5v (using the R3/R4 divider)
And then calculate the top right loop using KVL, going clockwise :
Vr3 + Vab - Vr1 = 0
Vab = -Vr3 + Vr1
Vab = -13.5 + 4.5
Vab = -9v
I've been reading though, that if you don't know the current direction, you can just assume a direction, and that as long as you stay consistant, the value will still come out correct. You'll just have to remember the direction is actually flipped if you get a negative current.
So I thought I'd try a different current direction.
But I get a different result using KVL :
Vr3 + Vab + Vr1 = 0
Vab = Vr3 + Vr1
Vab = 13.5 + 4.5
Vab = 18v
Have a misunderstood something here? .. I appreciate that in the above example the currenly is clearly going the other way, but I wanted to just try a different direction as I understood the direction could be arbitrary?
Picbuster
Joined Dec 2, 2013
1,058
Calculating this type of circuits;
always calculate from one pole of battery normally the minus pole.
Volt A from -batt = R2 * 18/(r2+r1)
Volt B from -batt = R4 * 18/(r4+r3)
The voltage between A and B= |(Volt A-volt B) I took the absolute value reason volt A is, in this case, higher then Volt B but don't know where A and B are connected to so I defined the potential difference.
Picbuster
Transatlantic
Joined Feb 6, 2014
44
Where in KVL does it state you can assume arbitrary current directions?
For example here http://hades.mech.northwestern.edu/index.php/Kirchhoff's_Current_and_Voltage_Laws
"The directions for the currents were chosen arbitrarily. Keep in mind that there is no "wrong" direction when choosing the direction of the arrow, as long as we are consistent with each current's direction."
It is my understanding that when using KVL to sum the voltages around a loop, you need to know whether to add or subtract the voltage at a certain segment in the loop.
"It doesn't matter if you go clockwise or counter-clockwise. If you go from a "+" sign to a "-" sign when going around the loop, subtract the voltage across that element. Otherwise, add it. Once you've completed the loop, set the summation equal to zero".
I thought you used the current direction to figure out if it's a + or - you are going through.
dl324
Joined Mar 30, 2015
18,330
going clockwise :
Vr3 + Vab - Vr1 = 0
Vab = -Vr3 + Vr1
Vab = -13.5 + 4.5
Vab = -9v
[snip]
Vr3 + Vab + Vr1 = 0
Vab = Vr3 + Vr1
Vab = 13.5 + 4.5
Vab = 18v
The equations should be the same regardless of direction. The second loop equation is correct. The first has a minus sign that you can't assume.
Transatlantic
Joined Feb 6, 2014
44
But take an example like that. Why have they chosen the + to be on the left of R2? Why isn't it on the right and the - on the left? How is it determined?
dl324
Joined Mar 30, 2015
18,330
They made arbitrary current direction assignments and that resulted in the polarity of the drop across R2 being what it is.
Transatlantic
Joined Feb 6, 2014
44
Which is what I thought I did? .. I made an arbitrary current direction.
Vr3 + Vab + Vr1 = 0
Vab = Vr3 + Vr1
Vab = 13.5 + 4.5
Vab = 18v
..and get the wrong answer. This is my confusion.
Jony130
Joined Feb 17, 2009
5,598
Also did your solution for VR1 is consistent with your assumed current direction ? The answer is NO.
Because if the current is flow from point A toward upper R1 terminal VR1 is negative (-4.5V) therefore
Vab = -Vr3 - Vr1 = 13.5V - (-4.5V) = -9V
dl324
Joined Mar 30, 2015
18,330
Vr3 + Vab + Vr1 = 0
Vab = Vr3 + Vr1
Vab = 13.5 + 4.5
Vab = 18v
If you determine the currents at the top node, you'll find that that gives a negative current for the direction you assumed through R1 and that will reverse the polarity of the voltage drop.
And you still need to show how you determined the voltage drops.
To do it with KVL and KCL, you need to setup equations for KCL and solve the simultaneous equations.
