You have not specified the model, unless I missed it. In any event, in an earlier post, you said that you found a breaker near the battery. It seems that some of these have more than one breaker - at least according to a post here http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=3865Well I got a new board and it still does the same thing. Runs for 10 to 15 feet then the wheels stop dead wait 30 seconds and away you go. Incidentally I noticed that the forward reverse switch on the car and the high low switch doesn't do anything either. Help please my grandson is driving me crazy!!!lol
Yes it runs fineI am still confused.
There are two motors.
You connect one motor to the battery and it runs ok?
That means the motors are ok and maybe the battery is ok too.Yes it runs fine
Yup that worked as wellThat means the motors are ok and maybe the battery is ok too.
Next step, can you run both motors at the same time off the battery?
I suppose you have arrived at this already.Yup that worked as well
Sorry its a s2588 2 wheel drive 24 volt side x side.You have not specified the model, unless I missed it. In any event, in an earlier post, you said that you found a breaker near the battery. It seems that some of these have more than one breaker - at least according to a post here http://www.modifiedpowerwheels.com/forum/topic.asp?TOPIC_ID=3865
If you have a vehicle that runs for a short period, and then stops, and starts again:.......There are commonly breakers somewhere else on the vehicle also. Some Power Wheels vehicles have one next to the throttle pedal. Some Peg Perego's have one in the Bus Bar under the switches.
It does still sound like a breaker, just maybe not the one that you found.
Just wanna thank everyone for their input!! Turns out the controller they sent me was bad. Just received a replacement yesterday and all is good.Sorry its a s2588 2 wheel drive 24 volt side x side.
