Just wondering, why are LM78XX & LM79XX series still made when LM317T and LM337T are available.
Ed Bray
Joined Feb 1, 2017
46
Pretty much as the title.
Why would you buy all of the LM78xx and LM79xx series when you can pretty much cover all the options with a LM317T and a LM337T. Are they not a one size fits all?
With the correct selection of components they can act as fixed voltage regulators and their range is not restricted to a specific value so should they be considered as useful stock items which means only carrying a pair of ICs rather than a multitude.
Just wondering.
Bordodynov
Joined May 20, 2015
3,431
It is more convenient to have a stabilizer with a fixed voltage. Do not need two precision resistors. You need less space on the board. There are more advanced microcircuits of stabilizers.
OBW0549
Joined Mar 2, 2015
3,566
I think neither the LM78xx/79xx nor the LM317/337 are used much in new designs, as they all have significant dropout voltages (1-2 volts for most parts) as well as being wasteful of current: the LM117/337 have a minimum load current (5-10 mA), and the LM78xx/79xx have quiescent (i.e., no-load) currents of around 5-8 mA. Low power and micropower low-dropout (LDO) regulators are often preferred for applications in which the entire system may draw only a few milliamps.
ErnieM
Joined Apr 24, 2011
8,415
Different strokes for different folks. And so on and so on and scooby dooby doo.
There is no such thing as the best part or circuit. There are devices and schemes with more advantages than disadvantages over others in some particular situation.
joeyd999
Joined Jun 6, 2011
6,279
Actually, nearly no one would design a 78xx or 317 into any new design for production equipment. Both parts are essentially obsolete.
Original manufacturers (and third parties) continue to produce parts for legacy designs as long as the volumes (and price) warrant it. Over time, these volumes will decrease and the price will necessarily rise. At some point, the cost of continuing to use the part will exceed the cost to redesign (or discontinue) the legacy product using lower cost modern parts.
At that point, the 78xx and 317 parts will no longer be available from manufacturers -- and the supply will only be available from surplus parts vendors and ebay.
Ed Bray
Joined Feb 1, 2017
46
Thanks folks its very interesting, I was just looking at my IC Box and I have a load of various 78xx and 79xx as well as 317T and 337Ts, and obviously for a hobbyist like myself it takes up valuable space. I just wondered what are the advantages of the fixed regs versus the adj regs (when used as fixed).
dl324
Joined Mar 30, 2015
18,326
They can't possibly be taking up *that* much space.
By the definitions given, I have many obsolete parts in my stock. I won't be getting rid of them any time soon because I also have many pieces of old test equipment that use those "obsolete" parts...
ErnieM
Joined Apr 24, 2011
8,415
Personally I can't remember the last time I used an adjustable regulator when I did not need adjustability, but I am a minimalist and always seek to use the very fewest lowest cost parts.
Component cost/count trade-offs can have some surprising trade offs. Once when I needed a high side driver I discovered using a low dropout regulator with an enable input that was cheaper and less components than the single transistor (plus resistor) I had been using.
hp1729
Joined Nov 23, 2015
2,304
Just wondering.
LM317 - $0.39 plus resistors
LM7805 - $0.29
Tonyr1084
Joined Sep 24, 2015
9,744
Both series regulators waste a lot of current converted to heat. Buck converters are much better design considerations. If battery life is being considered - a buck converter is going to out perform those older regulators - of which I have many too. They just sit in my static foam.
dendad
Joined Feb 20, 2016
4,637
Unless you REALLY need a linear reg, (or an adjustable one), and some times you do, a "drop in " switcher is the way to go now i think. Yes, they are more expensive, but the overall power saving is worth while, and no heat sink is required. I was using the Recom regs, like R-785.0-0.5 and R-78HB12-0.5 for up to 72V in, but now there are a number of other suppliers, like Traco TSR 1-2450, and a few others. These are worth looking at. They can now be found for under $10 each.
In a number of my products I use a switcher from 24V to 5V then a 3.3V Low Drop Out linear regulator for better noise specs.
AnalogKid
Joined Aug 1, 2013
12,126
Static current and minimum load current are not the same thing. With a 500 mA guaranteed load, the setting resistor current can be pretty low. The static current out of a 317 adjustment pin is only 50 uA typ., 100 uA max.
ak
joeyd999
Joined Jun 6, 2011
6,279
Early in my career I designed a high performance low-noise deuterium lamp driver using a "floating" lm317hv as a current source.
The performance was better than the typical opamp circuits of the day, and the ultimate performance was better (and far less costly) than the lamp manufacturer's reference design.
joeyd999
Joined Jun 6, 2011
6,279
Hey! That's my board!
Circa 1994.
