Just started complex numbers with AC circuits
Asmodeus25
Joined Jul 8, 2016
6
So we just started learning complex numbers, and One of my questions I don't seem to understand how to solve and I know its pretty important. A voltage sine wave with a peak value of 300V leads another Voltage sine wave of 200V peak value by 30 degrees. calculate the RMS resultant value of these voltage waves.
MrAl
Joined Jun 17, 2014
13,859
RMS means "the root of the mean of the square"
so first you square it, then find the average, then take the square root.
Try that and see what you can come up with.
MrAl
Joined Jun 17, 2014
13,859
im not getting the correct answer :/
Ok then i will do one for you for an example.
Say the voltage is 100 volts peak.
The waveform is:
Vt=100*sin(w*t)
or:
Vt=100*sin(2*pi*f*t)
Now square that and we get:
10000*sin(2*%pi*f*t)^2
now compute the mean and get:
(5000/f)/(T)
where T is the period which is T=1/f, so we get:
5000
now take the square root and we get approximately:
70.71067811865
But if you have not been taught that method yet then you just multiply by a constant factor:
100*K
and you get the right answer.
Do you know what the value of that factor K is?
WBahn
Joined Mar 31, 2012
33,321
You need to show your work. There's no way for us to help you find where you are going wrong if you don't show us what you did. We are not mind readers.
35,280
Do you know how to do vector analysis?
Since your question pertains to complex numbers, do you know how to represent 200V @ 30° phase angle in complex form?
Asmodeus25
Joined Jul 8, 2016
6
The waveform is:
Vt=100*sin(w*t)
or:
(5000/f)/(T)
5000
70.71067811865
100*K
I did this for both of them, but the answer in the text book is 280V and the rms of 100 and 200 is not even close to them. We havent used K factor yet
WBahn
Joined Mar 31, 2012
33,321
SHOW YOUR WORK!!!!
We are NOT mind readers. How can we possibly help you figure out what you did wrong when you refuse to show us what you did at all?
Asmodeus25
Joined Jul 8, 2016
6
Since your question pertains to complex numbers, do you know how to represent 200V @ 30 phase angle in complex form?
Yes, I think so, in polar its 200 V *angle sign* 45 degrees and the other is 100 *angle sign* 0 degrees. And I can then convert those to rectangular form and add them, and convert the rms, but the result isn't the answer that the textbook is giving me of 280 V.
Asmodeus25
Joined Jul 8, 2016
6
I figured out where I went wrong, after doing this, I apologize for the lack of work showing, this is the first time i'm using these forums. thanks everyone for the help
35,280
Remember, forums are not only about helping yourself.
There is an audience and other people can learn from your mistakes.
Please follow through by showing where you went wrong.
WBahn
Joined Mar 31, 2012
33,321
Huh?
How are you getting 200 V and 100 V from this problem statement?
How are you getting an angle of 45 degrees for the 200 V signal and 0 degrees for the 100 V signal?
Why won't you show your work?
What are the time-domain representations for a voltage waveform that has an amplitude of 300 V and that leads another voltage waveform that has an amplitude of 200 V at an angle of 30°.
What are the phasor representations for these two waveforms?
38,920
If those two waveforms are added in series, the simulated output result is 341.25Vrms (below), so I'm confused about the 280Vrms textbook answer.
KL7AJ
Joined Nov 4, 2008
2,229
You will never regret getting a good understanding of complex numbers. They are applicable in EVERY field of science, and they open up whole new levels of understanding. Take the time to understand and appreciate them. Blessings on your journey.
35,280
300V pk added to 200V pk = 500V pk = 350Vrms.
Hence the textbook answer has to be less than 350V rms.
I have yet to work out the correct answer.
MrAl
Joined Jun 17, 2014
13,859
I did this using both complex numbers and time domain expressions for the two waveforms and both times i get a number extremely close to:
342vrms
This should be more accurate than a simulation would show unless maybe the time step was very very tiny.
35,280
That is close enough. My answer by calculation is 341V rms depending on where I do my rounding.
If you want exact numbers I can provide it.
38,920
Yes, timestep does slightly affect the results.
With a maximum timestep of 0.1μs, the simulated voltage was 341.99Vrms (close enough for government work :rolleyes:).
