I've spent about 12 hours today reverse engineering this schematic and I think I've got it! But I would really like to test it and see if it works before aI make a new PCB. Awhile back someone was very helpful in testing/debugging a similar schematic on LTSPLICE. I've downloaded it and tried to figure it out, but am not having much luck. The one IC in my schematic is not in LTSPLICE's library, and I've googled and downloaded other symbol libraries, but to no avail. My plea is: Would someone have a little time to draw this up to see how it works in LTSPLICE--I think it should put out a variable voltage or a square wave, to drive a proportional hydraulic valve.
I've tried to make an orderly diagram, but I don't exactly understand what all's happening. I hope it's clear for you. For clarity, I labeled everything well, and then included a chart of the values. It's not a real big circuit.
Thank you so much for taking the time to look at this. I'll include the eagle file schematic that I drew this up in, also.
