JL Audio JX500/1 overheat
Balcar
Joined Aug 5, 2024
I have a JL Audio JX500/1 that had the power supply mosfets and a couple of BJT transistors damaged, I replaced all of the for brand new components, same batch, the transistors replaced were:
8 RFP70N06 (not sure if those are the original ones, it looks like those were replaced at least once before)
4 TTC5200, original ones were from toshiba, but I bought brand EVVO, I got them from digikey
4 TTA1943, original ones were from toshiba, but I bought brand EVVO, I got them from digikey
I checked the fets driver TL494CN with a scope, it is working fine, after that, I turn the amp on and it changed from protect to power mode, I connected a subwoofer and it looks like it is working fine, but after around 10-15 mins working, the output stage section is heating up very fast, power supply stage is very stable and is not hot, I decided to turn the amp off before it gets damaged again.
The output driver transistors used in this amp are the TP41 and TP42, I don't know if those are the originals or were replaced before, in some threads I read that these transistors are not good as drivers, do you know if these transistors are the original ones used by this amp?
what can be causing that the amp is heating up very fast only in the output power transistors (C5200 & A1943)
I really appreciate your help.
thank you
28,224
TRansistors get too hot because the current is too much. So if the circuit is shown then it should bepossible to adjust the bias and reduce the current. I have seen the same sort of repairs done before, replace the burned out part without solving the problem that made it fail.
So we need to see the circuit of the amplifier.
