Issue with simulating this digital circuit
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
Attached is the digital circuit of the MC14518B, and its timing diagram. I want to implement the flip flops directly using logic gates since I will then build a VLSI model. The problem is that I'm trying to simulate that circuit and to get the same time diagram as the datasheet says, but it's not been successful. I'm using Proteus but I don't get the same timing diagram. Do you know another more reliable software for this purpose? I also attach the equivalent circuit I'm using for the D Flip Flop. Maybe it's not the sofware but another thing I should take into account.
What are your suggestions?
38,831
I would think the problem is more likely in your model, then with Proteus.
Show the exact circuit from the simulation screen and the results.
38,831
Does one flip-flop work properly by itself?
When you get one working, then it will be easier to connect them together and get all of them working.
