Isolation requirements
benassve
Joined Nov 1, 2023
10
I am developing a high voltage BMS which will have isolation resistance measurement, high voltage measurement, current measurement and etc. Is it necessary to use isolation amplifiers and relays. What is the benefit of maintaining isolation between a high voltage system and a low voltage system. Are there any standards that would require this function (IEC62477 for example). A battery with BMS would be used with solar panels and inverters.
thank you!
BobTPH
Joined Jun 5, 2013
11,662
If the high voltage is charging a low voltage battery, then I think a transformer is the only practical way to isolate them.
Please give us a block diagram at least so we have some idea of what you are trying to do.
ronsimpson
Joined Oct 7, 2019
4,845
Isolation is good for more than one reason.
Some battery projects are under 48 V and isolation is not critical for safety.
For the car projects, have used 400V or 800V batteries. That will kill you.
Even on 12V batteries there can be large differences in ground voltages. To measure the battery accurately, you need to measure right at the battery not down the line. Isolation helps that.
28,454
The short answer is "YES, Isolation is required".
BUT the TS provides not nearly enough information to allow any more detailed advice to be provided. And certainly the measurements mentioned will require additional descriptions so that suggestions as to what would be isolated from what can be described.
