Thanks a lot for the information
The CPU is primarily a digital circuit -- any analog circuits are generally very few and for purposes peripheral to the CPU's job. The overwhelming majority of modern CPU's use CMOS circuits in which transistors are used as switches to either connect nodes to a HI voltage or a LO voltage. Each switch serves a particular role in the logic implemented by the CPU. The more things you want the CPU to do, the more switches (transistors) you need.
| Thread starter | Similar threads | Forum | Replies | Date |
Audio amp pwr transistors (low hFE, and other spec rot) | General Electronics Chat | 16 | |
Thyristors Did to Power What Transistors Did to Logic | Power Electronics | 3 |
