Completed Project Is this resistor adequate for converting a 250W PSU to bench supply?
Rahulk70
Joined Dec 16, 2016
538
Hi guys,
I have attached a 20 Ohm resistor to my Dell PSU on the 5V rail since its a 2004 PSU and most of the current are in the +3.3V & +5V rail. I have seen on most youtube videos where they mention using such dummy loads but they are usually those ceramic resistors. I dont have one in my posession now. Just attched this resistor I had previously salvaged from an old Nokia charger. I have attached a picture below for better idea.Thanks in advance everyone.
Dodgydave
Joined Jun 22, 2012
11,395
It will work ok giving you 250mA drain current, it will be fine for a dummy load, if your psu won't keep running put another 20 ohms in parallel or change it for a 10 ohms @5W.
ian field
Joined Oct 27, 2012
6,536
Hi guys,
Sometimes I use car bulbs - but you have to be a bit careful with the higher ratings, bulbs radiate more IR than resistors so its not impossible to set fire to things.
Rahulk70
Joined Dec 16, 2016
538
I have two bulbs with me a 21W signal flasher bulb and a 60/55W headlamp. Thought of adding the 21W but like you mentioned heat will be an issue also this supply since its 250W there is limited space inside just enough for my binding posts.
Rahulk70
Joined Dec 16, 2016
538
After attaching this load resistor, I tried running it with my Mini peltier cooler as its current draw was initially 3.1A and then it dropped and settled at 2.78A. The resistor was hot but not hot that it will burn or didn't produce that burning smell.
Rahulk70
Joined Dec 16, 2016
538
I just went through my entire collection and was able to find only one ceramic resistor 1 Ohm 5Watts which I guess wont do the job.
ian field
Joined Oct 27, 2012
6,536
The headlamp bulb is certainly a fire risk - but you don't need to apply that much load to make it work.
Usually only the 3.3 & 5V rails are sensed for regulation, when they get up to speed the PWM throttles back until you draw some load. Meanwhile - the other rails aren't monitored (except by the OVP) so they might well collapse if you draw current from them.
Rahulk70
Joined Dec 16, 2016
538
Update: Yes thats the reason why current I've added two 20 Ohms resistors in parallel. I hope thats sufficient to maintain the load. I do have one ceramic rectangular resistor but its only 1 Ohm 5W.
Rahulk70
Joined Dec 16, 2016
538
Also I have one question. Should I add an automotive 12V 15A fuse in line with the main +12V yellow line where all the wires are bunched together to the binding post or the inbuit short-circuit protection will take care of overload /short and shut it down?
ian field
Joined Oct 27, 2012
6,536
Even the 12V rail can shift a fair bit of current and is a lower priority on overload protection - a fuse is a good idea.
Rahulk70
Joined Dec 16, 2016
538
My +12V rails are capable of 16A. I just tried deliberately shorting the 12V and GND and the there was a tiny spark and the PSU shutdown. After resetting the Green and Black wire the PSU turned back on. But to see how it performed when connected to large current pulling devices, I had a 12V car cigarette lighter with me. Connected it to my 12V rail bunch and GND. In 12 Sec the plug was out and glowing bright orange. So, I think adding an inline 12V fuse is a must. The only thing is that I'm confused about the value.Should I go for a 15A or 20A fuse(PSU max +12V@16A)? I'm concerned if I add a 15A fuse will it blow sooner since the 12V line is 16A or if I go for 20A its too far from rating and it wont blow
ian field
Joined Oct 27, 2012
6,536
You could try a bit of experimentation - what's the biggest fuse that blows before the PSU trips.
If it trips safely without self destructing - you could dimension the fuse specifically to protect the load rather than the PSU.
Rahulk70
Joined Dec 16, 2016
538
I've currently added a 15A auto fuse. I decided to go with it since the biggest 12V load I've ever connected was I think a 130/100W halogen bulb at 10.8 A briefly connected and it did fine. But the heat blowing from the PSU increased very much. I'll try connecting the cigarette lighter also to see how much current it will be able to handle max. Ian I've a question related to another Dell 210W PSU which I use as a bench supply too. The output at +12V rail is only 11.68V on that PSU. I tried opening the cover and therer is a POT at output. The max value I can vary it to is +12.68V. What is the safe value I could increase too without compromising the PSU?
ian field
Joined Oct 27, 2012
6,536
The limiting factor is usually the voltage ratings of electrolytics on the other rails.
Some PSUs have 6.3V electrolytics on the 5V rail, so you may need to keep an eye on that. 12V rails usually have 16V caps, so shouldn't be any problem there. Sometimes the 5V rail has 10V caps, which are unlikely to be a problem.
Shottky barrier rectifiers are usual, which tend to have pretty close headroom - probably not a problem for what you intend, but you can always search out the data sheets and see how much room to manouver.
You can add snubbers to SB rectifiers in flyback converters, but I doubt it does any good in push-pull types.
Rahulk70
Joined Dec 16, 2016
538
Thanks Ian. Currently I've set it at 12.05V and the 5V rail has 5.4V so I guess its within the safe limit and +3.3V rail seems to be pretty stable, around 3.34V.
