Is This Possible and What Relay Do I Need
CTCGunny
Joined Jan 6, 2018
6
Hey Folks,
I'm a NOOB here and am working on a automatic system for my greenhouse design and I need some help. Is this relay in existence, and where can it be found?:
Any help is appreciated.
Thank you in advance for you assistance in this matter,
Chris
ElectricSpidey
Joined Dec 2, 2017
3,334
Yea, Amazon will have these, but you may want to skip there and use a reliable source like Digi-Key and such.
A DPDT relay with 120 volts ac coil.
The size will depend upon the motor size.
CTCGunny
Joined Jan 6, 2018
6
As long as the coil get enough voltage, the other pins really don't care what the voltage is as long as it doesn't exceed specs, right?
it's a loaded question, but a first order answer is true.
A contact will have AC and DC ratings, but a contactor for a motor usually is rated in horsepower. They also might have a minimum current and a switching current.
Too bad you don't have 12 VDC available, because 30-40 Amp automotive relays which have a 12 V coil are perfect. Wait...Your batteries are 12 V.
So, get an automotive relay for the DC motor and switch the 12 V coil with a simple low current 120 V coil relay.
Tonyr1084
Joined Sep 24, 2015
9,744
I shudder when I see someone wanting to run a fan continuously from a battery. And when you change directions you slam the motor with the opposite current. Given the massive draw and the Back Electro Motive Force (BEMF) a 10 amp motor can easily cook a relay designed to handle 40 amps under those conditions.
Wouldn't it be better to design a set of relays so that you can run the fan one way or the other OR off when the fan is not needed ? ? ? And wouldn't it be a better design if the fan was powered from something other than a battery ? ? ?
GopherT
Joined Nov 23, 2012
8,009
Hey Folks,
Chris
If you lean to run a fan in reverse, you may run into issues unless the fan was designed for two-way ventilation. Some blade designs are very inefficient when run in reverse.
Bernard
Joined Aug 7, 2008
5,784
Linear Actuator 00000.jpg Do you have any specs. on lin. actuator. Your drawings are OK, relay 12 V coil, DPDT contacts.
Possible drawing of actuator.
CTCGunny
Joined Jan 6, 2018
6
Seems as though the "property police" put the kaboshes on the greenhouse. So all of this was for nothing. Thank you to all who took the time to answer.
Again, thanks for the help,
Chris
