Is this IR ckt Right
ericgibbs
Joined Jan 29, 2010
21,565
hi,
This is a clip from that Amazon advert:
Clear Round Infrared 940 nm DC 1.2V 30mA 100mW) Lighting Bulb Lamps Electronics Components Light Emitting Diodes
So the maximum current is 30mA, so recalc the resistor values to suit 1.2v at 30mA.
If you still have insufficient IR radiation choose a higher power LED.
E
Raj Pandey
Joined May 27, 2019
62
hi,
E
I think it will work After I make a PCB and do testing I can say for sure.
djsfantasi
Joined Apr 11, 2010
9,237
You think what will work?
Your three LED strings should have a 47Ω resistor in series with the LEDs. The string with two LEDs needs a 82Ω resistor (using standard resistor values. Go back to ericgibbs or my calculations to see why.
Raj Pandey
Joined May 27, 2019
62
I have placed a 57Ohms resistor around 3 LEDs in series and 100 ohms with 2 LEDs in series.
On calculating I got 24.56mA for 3 LEDs and 26mA for 2 LEDs. So this will work right. there will be no issues.
Raj Pandey
Joined May 27, 2019
62
hi R,
It should work OK.
If the operating range of the remote is insufficient, you will have to use higher powered LED's
E
Ok, I will now make it on zero PCB and test it by sending the signal through ATMEGA328P used as a custom Arduino for control.
