Is there more information needed or am I just missing how to start this solution???
Rendog
Joined Feb 8, 2019
I am stumped where to begin. I am not looking for the answer just some help getting started!!! Do I start through resistor 4 or through the parallel resistors 1,2,3?20190208_060946.jpg
38,797
First I would combine the parallel R1 and R2 into their equivalent single resistor value.
Then you should be able to write the two loop equations to solve for the unknown.
Rendog
Joined Feb 8, 2019
OK I am getting 57.7 ohms for r1 and r2. can i know just do the series and bypass r3 to find a total. I think the current on R3 is throwing me off.
WBahn
Joined Mar 31, 2012
33,182
It appears that the problem is using electron flow for current. That often indicates that this is being taught in a course that is very light on theory, often taken by students whose math background is not very extensive. Of course, this isn't always the case, so it would help us help you if you could describe the type of program this is in and how strong your math skills, particularly algebra, are.
In the meantime, assume that you know the voltage on the top-right node (let's call it Vo). Can you write the equation for the currents entering and leaving that node (i.e., Kirchhoff's Current Law)?
WBahn
Joined Mar 31, 2012
33,182
If the top of the 66 volt source is the positive end, as would be usual, the direction of the 1.3 amps is odd.
According to the battery symbol, the top is, indeed, the positive end. The direction is only odd if it is using conventional current, which is why I suspect the course is using electron flow (which should be banished unless it's done correctly, and I've never seen it done correctly yet except by a couple of physicists I've worked with).
Rendog
Joined Feb 8, 2019
That is what is throwing me off i think. All of our classes he has taught the current going clockwise and labeled the resistors as so. The arrow pointing in the opposite direction is what throws me off.
JoeJester
Joined Apr 26, 2005
4,390
According to the symbol for the current flow in R3, the diagram is for conventional flow. It would be the other direction for electron flow.
The Electrician
Joined Oct 9, 2007
2,986
Wbahn , you say "most" of the drawings you've seen tend to get that right, which probably means that you have seen some that don't get it right. Also, I get the impression that you haven't seen many uses of electron current in problems for beginners. So, what is the relative occurrence of bad battery symbols versus the rate of occurrence of usage of electron current? Do we need to take those rates into account as we invoke Occam's razor?
I don't know where the "odd" aspect occurs in this problem, but something's atypical about it.
The Electrician
Joined Oct 9, 2007
2,986
If the top of the battery is positive, the current arrow on R3 is wrong for conventional current (if the resistor is an ordinary passive resistor).
OK. Ignore the arrow for now. What network solving methods have you learned? Can you follow WBahn's suggestion to describe what happens at the upper right hand node?
38,797
You can draw the loop arrow in either direction as the direction is completely arbitrary.
It still gives the same answers as long as you draw all loops in the same direction and use the appropriate polarity for all the component voltages around the loop.
Huh?
Would you agree that the diagram shows the voltage at the top-left node being 66 V higher than the voltage at the bottom-left node?
If so, then would you agree that conventional current flows clockwise around the circuit?
If so, then would you agree that the voltage (relative to the bottom-left node) is lower than 66 V (but greater than 0 V)?
If so, then how is current flowing right-to-left in the bottom resistor consistent with conventional current flow?
Apparently you missed post #17
