Is there any 120VAC outlet with interlock ?
Externet
Joined Nov 29, 2005
2,676
Hi.
Am exploring to install/add a heating element mounted and with the size/shape of the outlet blowing grille of a plain 5000BTU window air conditioner that will disconnect its compressor to disable cooling.
It would be nice to have a single outlet receptacle that switches-off an auxiliary mechanical contact when a plug is inserted.
Anyone knows how to find one, or perhaps ideas to make one ? AC manufacturers want zillions for a $5 addition of a heating feature.
Externet
Joined Nov 29, 2005
2,676
Adding an microwave-oven-duty interlock microswitch to one of these would be nice. When a plug is inserted, to act a microswitch behind it...
schmitt trigger
Joined Jul 12, 2010
2,229
I was also going to suggest something similar, but Crutschow replied much faster.
Nowadays the state of electronics is that, whatever gadgets one can think of, there will be something already available, fully assembled and tested and in a nice plastic enclosure, for sale at Amazon, Aliexpress, EBay or any other e-commerce website, at a price lower than the cost (to you) of the raw components themselves.
MisterBill2
Joined Jan 23, 2018
28,276
What I have seen is an OUTLET COVER that operates a switch when it is opened to allow a plug to be inserted. The immediate benefit is that it does not handle the power and so many rules do not apply. So that could be an alternative solution. AND it could be much safer.
MisterBill2
Joined Jan 23, 2018
28,276
Hi.
View attachment 371088View attachment 371089View attachment 371090
Adding a heated function to a typical "window size" air conditioner could be done by "simply" exchanging the condenser and evaporator connections. EXCEPT that it would not be at all simple!!!
Adding electric resistance heat to an AC unit has already been done and is in a commercial product that is not commonly available.
NOTE!!!! There is NO WAY any heating function could be added to a window-sized AC unit for even $5! Maybe for $250 that would not be safe to use !!
Ian0
Joined Aug 7, 2020
13,278
Hi.
If it is already cold enough, and cold enough to require a heater, then the thermostat will disable the compressor.
MisterBill2
Joined Jan 23, 2018
28,276
What compressor do you need to lock-out?? And why are you not simply able to switch it off ?? If heating is required then the cooling thermostat will stay OFF, won't it?? I think that I sawan interlocked outlet in a hardware store back in about 1956. Things have changed a whole lot since then.
