I am curious to know if there's a circuit or a way to utilize an enable pin to turn on/off an IC without a microcontroller.
There are multiple ways to do this. We just need more information.I am curious to know if there's a circuit or a way to utilize an enable pin to turn on/off an IC without a microcontroller.
yes, so I have a gate driver (low side) that has an enable pin, and I would like to turn it on if it senses a signal from (pwm) coming from the source into the input of the driver, and I would like for it remain off if it doesn't detect that signal.There are multiple ways to do this. We just need more information.
What will initiate this action?
What is the load, i.e. where is this signal to be used?
Can you provide a circuit schematic of your application?
Thank you very much, this worked exactly like I needed.If the PWM peak voltage is the same as needed for the enable pin, then you could just use a series diode and capacitor to ground to rectify the signal to give a DC level.
How fast do you need to turn the enable on and off when the PWM signal appears and stops?
What is the PWM frequency?
I would like to turn it on/off as fast as possible the frequency of the pwm is 4kHzIf the PWM peak voltage is the same as needed for the enable pin, then you could just use a series diode and capacitor to ground to rectify the signal to give a DC level.
The theoretical fastest would be 1 cycle of the PWM or 250us.I would like to turn it on/off as fast as possible the frequency of the pwm is 4kHz
I got the problem sorted out. I will implement the enable pin on software. Thanks!This discussion looks like a continuation of
https://forum.allaboutcircuits.com/...ary-pwm-with-dead-time-2.187731/#post-1743709
to me.
Did you not sort out the problem where there was a high current flowing when both low-side MOSFETs were on?
If not then trying to disable the driver isn't going to help.
Now it is fairly clear that the TS was referencing some specific IC device, which the TS did not mention which device. So this was another case of the lack of mind reading ability for many of us leading to a lack of communication .I am curious to know if there's a circuit or a way to utilize an enable pin to turn on/off an IC without a microcontroller.
Controversial - but I agree.The micro is especially handy for those unable to create logic circuits that work.
Not really true anymore !Most of the real world does not include microprocessors.
That comes off as a little condescending, IMO ?!The micro is especially handy for those unable to create logic circuits that work.
A lot condescending IMO. (from an expert on condescending per some here)...
There were those that were probably saying that when IC's appeared and replaced discrete transistor circuits!![]()
| Thread starter | Similar threads | Forum | Replies | Date |
| S | Calculating LC Notch filter bandwith and another question | Analog & Mixed-Signal Design | 0 | |
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 72 | |
Another good one | General Electronics Chat | 27 | |
Another battery thread | Power Electronics | 8 | |
another patch... | General Electronics Chat | 11 |
