Is there another logic IC, similar with 4017 but with up/down counting? (not only up)
Status
Not open for further replies.
Ya’akov
Joined Jan 27, 2019
10,370
And an 8 pin microcontroller can be had for about 50 cents. Unless you sufferer from fear of programming, it is the simplest solution.
Assuming this dream chip is just a part of a larger system, the bent result of using an MCU may well be an overall savings—and a heck of a lot more flexibility.
Ian0
Joined Aug 7, 2020
13,317
I suppose.
Guess us old analog/discrete-digital types are doomed to extinction. :oops:
But I won't give up my op amp, 555, and CD4000 circuits until they pry them from my cold ,dead hands.
I guess we are. They may have to bring us back from retirement when they want a logic circuit to work on a 12V supply with 3V of ripple, and don't have room (on the board or in the budget) for a 3.3V regulator and its filter caps.
I often find it helpful to design a circuit in logic gates even if I never make it like that but translate it into code. It helps to find the "undefined states" that might catch out the software.
hrs
Joined Jun 13, 2014
539
It's not clear to me at what voltage the CD4017 will run and what it'll be driving.
I'm contemplating a similar issue using 12V probably and use the CD4017 to drive other CMOS inputs. Then, for up/down counting, the single chip MCU solution becomes 1xMCU, 1x5V regulator plus caps, 1x transistor plus resistors for each output that you need to translate to CMOS high/low.
So this is not to hijack the thread, but to state that depending on requirements the 'single chip' MCU solution is not so obvious to me.
Ian0
Joined Aug 7, 2020
13,317
Agreed. A “single chip” MCU is only a “single chip” solution if you already have a suitable power supply!
Ya’akov
Joined Jan 27, 2019
10,370
Read the OP again. He said he knew how to do it with two ICs, but was looking for a single IC.
When I started to compose my answer that paragraph was not part of the post. His answers to me also suggested he didn’t know how to do it since he said my suggestion “wouldn’t work”.
Ya’akov
Joined Jan 27, 2019
10,370
Wikipedia has a list of all the 4000 series devices that have ever lived.
https://en.wikipedia.org/wiki/List_of_4000-series_integrated_circuits
It’s often worth a look through it especially the 401xx and 45xx devices. Then you can be disappointed whe you find exactly the device you need but that it was discontinued aeons ago.
Maybe @BobTPH could found a system that produces anything from the catalog using PICs and webserial. You just need a pile of pics, and programmer—look up your device and (assuming someone has provided a .bin for it) click on “burn it”, et voila! Instant perfect logic chip.
I am sure there would be at least… 10… users for such a thing.
Ian0
Joined Aug 7, 2020
13,317
Wasn’t it called a logic array? I have some GAL16V8s, but I don’t have a power supply big enough to run them.
Status
