Is there a way to use a P channel fet like a switch and hold it closed even when there is 0V across it?
mike _Jacobs
Joined Jun 9, 2021
223
Was trying to think of how to do that without a bipolar power supply.
I only have a single available.
Anyone have any ideas?
mike _Jacobs
Joined Jun 9, 2021
223
The MOSFET will stay ON (closed) as long as the gate-source voltage is at or above the value given in its data sheet for the minimum Rds on-resistance.
This is typically -10V for a standard P-MOSFET.
As i said, i dont have a negative supply.
So if the source = 0V and the lowest voltage i have is ground then 0-0 = 0
Hence my question.
38,325
Perhaps if you explain exactly what you are trying to do with the MOSFET, we could better come up with a solution to that.
WBahn
Joined Mar 31, 2012
32,706
Hence my question.
It's the gate-source voltage, Vgs, that matters.
That means that the gate voltage would need to be 10 V below the source voltage. If the source voltage is 20 V, then the gate voltage only needs to be 10 V or less.
There are many PFETs that are fully turned on with less the ten volts. You just need to check the specs.
You REALLY need to post a schematic (or sketch) of how you want to use this transistor.
When used as a switch, the source of the PFET is normally connected directly to the positive supply voltage.
mike _Jacobs
Joined Jun 9, 2021
223
There is no circuit to post. I am wanting to treat a PFET like a solid state relay.
I want it to stay closed for a very particular reason. It has to do with something much more complex from a transient standpoint.
Just trying to explore if there is a way to make a PFET stay closed with 0v from S->D without a negative supply.
WBahn
Joined Mar 31, 2012
32,706
Again, if there is 0 V from source-to-drain, what does it matter whether it is closed or not? No current will flow in either case.
If you want to keep it in the linear region, the you need to keep the gate voltage lower than the source voltage by at least the threshold voltage. That does NOT mean that you need a negative supply.
Again, if the source is at 20 V and the there is 0 V between source and drain, that just means that the drain is also at 20 V. If the threshold voltage is -8 V, then applying 5 V to the gate will give you a gate-source voltage of -15 V and the transistor will be on (i.e., closed) very hard.
AnalogKid
Joined Aug 1, 2013
12,050
Try this . . .
1. What voltage is powering your circuit?
2. What voltage do you want the FET to switch on and off?
3. How much current will be going through the FET?
To be "turned on", the gate of a p-channel FET must be negative *with respect to its source*. That is *not* to say it needs a voltage that is negative with respect to the circuit GND. If you have a circuit with a +12 V supply, and that is what you want to switch with the FET, then when the gate is tied to GND, it is at -12 V with respect to the source, which is up at +12 V.
Positive and negative always are relative to something. In this case, the gate is negative relative to the source.
ak
WBahn
Joined Mar 31, 2012
32,706
If there is 20 volts on the source and drain then the FET is already ON.
Not if the gate is also at 20 V.
The TS seems to be struggling with the very critical distinction between the voltage at a node (as measured relative to some arbitrarily defined "ground") and voltage between two nodes.
cmartinez
Joined Jan 17, 2007
8,725
Hello, Mike. Try googling "high side pFet".
If I'm understanding you correctly, you'd like a circuit that would "latch" its state even if voltage to the pFet is removed?
LowQCab
Joined Nov 6, 2012
5,101
Please provide at least a Block-Diagram-Drawing and
a full and detailed description of the problem that You are trying to solve.
DickCappels
Joined Aug 21, 2008
10,661
And in addition to @cmartinez 's question, how it the P-channel switch to be connected between the + power supply and the load. Is the load grounded? This should not be had to get right once we understand what you want to do.
AnalogKid
Joined Aug 1, 2013
12,050
Correct that is a good way to think of it.
OK . . . how is that supposed to work? I probably missed something here, but . . . The most basic solid state latch + power switch requires two transistors, and transistors need electrical energy to function. Other than a flash memory cell, how is the latch state to be remembered without power?
ak
