The resistance of your inductors is surprisingly high. The 180uH inductor I recently used in a switching regulator design is less than 0.2 ohms. I thought open loop switch control and the inductor would be the source of your high current.Both the inductors have around the same resistances. One is 15 ohms and the other 20 ohms.
You need to monitor the output voltage and adjust the duty cycle or frequency of the switch accordingly.I didn't know that a feedback loop was required.
You have no feedback loop, so the output voltage will depend on the load. If the load decreases, the output voltage will increase. If the load increases, the output voltage will decrease. Basically no voltage regulation at all.
Basic block diagram from 1979 Signetics Analog Applications Manual:
