I want a device to be switched on outside the house with a switch. The device is connected to the ac source without the netural wire, it is a 2 legs plug. So is it safe to just left the earth wire to be outside the house with the on/off switch ( the live wire is completely placed inside the house)?
Also, can a home circuit breaker protect against electrical shock of device connected without a netural wire?
Any advice?
The first time I keep it remembered in the school, E-L-N, was some 30 years ago. I have mistakenly the two earth and neutral wires. So sorry about this.
I rewrite the original question above as follows:-
I want a device to be switched on outside the house with a switch. The device is connected to the ac source without the earth wire, it is a 2 legs plug. So is it safe to just leave the neutral wire to be outside the house with the on/off switch ( the live wire is completely placed inside the house)?
In case this plan does not work, what would be the best ways to switch on the in-house device?
Any advice?
