Is it accurate way to use Shunt Resistor measuring less than 10mA current
vishnuatacc
Joined Dec 26, 2017
Hello all,
I want to measure how much current consume for a coin cell battery operated wireless sensor network, the expected range of current is below 10mA. Is it accurate to use the shunt resistor method for this type of measurement? or any best methods are available. If the shunt resistor method is a good way, how can I decide the resistor value, such that I can get accurate results?
Thank you
D.Vishnu
ericgibbs
Joined Jan 29, 2010
21,423
hi,
If you used a1R shunt resistor in series with the high side of the battery output, a 10mA current will read 10mV across the 1R.
E
10mA = V/R = 0.01/1
ScottWang
Joined Aug 23, 2012
7,499
Using 0.1Ω shunt resistor then V= I*R = 10mA * 0.1Ω = 0.001V = 1mV
What range of the shunt resistor that you should use, that is depends on the accurate voltage that you want as 1mV or 10mV.
Reloadron
Joined Jan 15, 2015
7,882
If this is going to be a one time test I would use a commercial DMM (Digital Multi Meter) with a low DC current range placed in series with your load. Just as an example a basic Fluke 87 DMM has a 40 mA DC current range and offers 0.01 mA resolution and an uncertainty of ±(0.2% + 2). You make no mention of the resolution or measurement uncertainty you desire? While you can use a shunt the signal off the shunt will be a very low DC voltage which will likely need filtering for noise and amplification.
Ron
