Hi all.
This maybe a hard job but I'm trying to do it. I have a hear iron to repair. The temperature can be adjusted by a small potentiometer. A TO-220 component (without the metal back) is damaged, it is broken into two parts, the front part that contains the part number "disappeared", maybe it had fallen somewhere but I couldn't find it. So this is the unknown part that I want to know.
I made a picture to clarify how it is connected in the circuit, without reverse engineering all of the circuit.. and took a picture for the circuit board.
I had a small 220V-110V wall adapter that is in the size of a 220V to 9VDC 500mA wall adapter, or a 220V-110V 50W wall adapter. But this adapter that I'm taking about was something like 2500W or even more!. It was used with an electric coffee maker. I'd opened the adapter and found that there is a very small circuit with a thyristor mounted to a big block of aluminum that was almost taking the size of the adapter. I know Thyristor transformers are used with resistive loads only, and I think they use phase shifting to "transform" voltage.. I'm taking about this because the hair iron is also a high wattage resistive load. One final thing to say is that the Thyristor/MOSFET/?? in the hair iron is not mounted to a heatsink and it even don't have the metal back that could be mounted through.
Any ideas?
Regards,
Hazim
Any ideas?
Regards,
Hazim
