Is discrete input signal still raw after it is debounced ?
naseeam
Joined Jan 4, 2017
82
Consider a typical Automotive Embedded Software System.
A discrete input signal is 0 or 1. An example of discrete input is ignition ON or OFF.
After discrete input signal is debounced or a state change is latched, is discrete input signal still raw value?
Second question: Should Electronic Control Unit (ECU) low level software debounce discrete inputs or just read the real time state of discrete input? Are there any exceptions meaning some discrete inputs should be debounced, whereas others don't need to be debounced?
Papabravo
Joined Feb 24, 2006
22,111
Debouncing is done when there is a mechanical switch that makes and breaks multiple times as the contacts engage and disengage. If the digital input is coming from a source that is not derived from a set of actual switch contacts then debouncing would seem redundant.
naseeam
Joined Jan 4, 2017
82
By "raw value" I mean discrete input signal coming into microcontroller is as is, it has been conditioned or modified.
That's as clear as mud. For a bool variable there are only two values/states while the raw electrical input signal to the micro-controller could have a very large range of values the debounce function reduces to a bool as a factor of time and present state.
ErnieM
Joined Apr 24, 2011
8,415
If "raw value" means "as is" then the debounced signal is not a raw value.
Do I get a prize for playing the overly pedantic definition game?
[/insert Gordon Ramsey Joke here]
