is Delta or Star an option for this motor?
Keith Robinson
Joined Nov 30, 2014
53
I recently replaced a 3 phase 2.2Kw motor on a bandsaw so that I could utilise a VFD for speed control. I thought that the original motor wouldnt switch between star and delta as it only had three connections. Looking closer I see that it has six wires coming out to the junction box. could these be reconfigured to make it useable with a VFD controller. If so how would I identify the correct wires?. any advice would be much appreciated. KeithIMG_4270.JPG
Reloadron
Joined Jan 15, 2015
7,947
There is a good possibility the six wires are for configuring High or Low voltage, for example 240 or 480 Volts. Do you have the nameplate data for the motor? The nameplate data should tell you what you want to know.
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,808
What is the 3 phase voltage you are using? the motor appears as it is already in Delta, (low voltage), there does not appear to be the normal terminals for setting Star or Delta options, where there is normally 6 terminals supplied.
Max.
Keith Robinson
Joined Nov 30, 2014
53
Max.
thanks so much for your input. here is the plate details
LesJones
Joined Jan 8, 2017
4,543
As the motor looks like it was designed to run on 415 volts (Phase to phase.) in delta configuration if it was connected in star configuration it would require 719 volts phase to phase. Which would be 415 volts phase to neutral if there was a neutral.
Les.
Keith Robinson
Joined Nov 30, 2014
53
Ron
thanks for your response, heres the plate
Keith Robinson
Joined Nov 30, 2014
53
Les.
oh right! sounds like its a non starter then to work with a FVD on 230v ac. many thanks for your help
Keith Robinson
Joined Nov 30, 2014
53
Max.
Thats why I thought that the six wires might equate to the six terminals. the motor i replaced it with has the six terminals and was easy to configure to work with the VFD. I have another machine that needs a VFD so before I commit to another motor I am exploring using this old one.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Also a 6 pole motor at that rpm. I guess due to fitted to a band saw?
Usually star/delta connecting motors have the 6 terminals laid out 3 above one another.
Max.
Keith Robinson
Joined Nov 30, 2014
53
Max.
yes, like the replacement one. I just thought the six wires might be used like the six terminals. the new motor was easy to reconfig to work with the VFD just move the terminal links and hook up to the VFD. then 230v and speed control. I wondered if i could use a meter to determine which of the six wires would be equivalent to the six terminals found in a dual star/delta motor. perhaps i should remove the end caps to see if there is a centre tap?
28,279
Ron
I think that Ron is correct.
I recently replaced a 3 phase 2.2Kw motor on a bandsaw so that I could utilise a VFD for speed control. I thought that the original motor wouldnt switch between star and delta as it only had three connections. Looking closer I see that it has six wires coming out to the junction box. could these be reconfigured to make it useable with a VFD controller. If so how would I identify the correct wires?. any advice would be much appreciated. KeithView attachment 148030
And why did you consider that either star or delta windings were not suitable for use with a variable speed drive? I have used both with three phase drives, and they work.
MaxHeadRoom
Joined Jul 18, 2013
30,808
It appears to me the the OP was hoping to configure for 240v in order to run off of 1 phase residential.
Max.
Keith Robinson
Joined Nov 30, 2014
53
hello, thanks for your thoughts. I was hoping to use single phase 240 domestic mains to run the bandsaw with its original motor via a VFD.
I was told that if the 3 Phase motor didnt have the six links in its junction box to reconfig it to low voltage then it couldnt run off 240v even with a VFD.
I bought a new 3PH motor with the six links and was able to use it with the VFD very successfully. looking closer into the old motor as I am selling it, I noticed it has six wires coming from internally to its junction box. I thought these might equate to the six links. hence the query to more knowledgable people via this media. sorry for not explaining myself better originally. thanks again for the input.
Keith Robinson
Joined Nov 30, 2014
53
thank you for your input, perhaps Ive not made myself clear enough. please see my response to MrBill2. looks like the old motor wont work on single phase 240v whatever was done. Kind regards for your help.
28,279
Max.
Using a VFD is an easy way to get the three phase power that the motor requires. The drives that I have used will work with a single phase input or 3-phase, although the max power out is reduced a bit. And a friend did that with a Bridgeport milling machine at his home shop.
shortbus
Joined Sep 30, 2009
10,049
As usual you don't read the whole thread. You seem to have missed what Les and the TS said.
Les.
So just how is a 220V VFD run a 415V motor?
