IRL540 MOSFET
Dadu@
Joined Feb 4, 2022
155
I have found MOSFET datasheet. I have attached datasheet but I don't understand how much gate to source voltage it needs to turn on fully. Where can I see this information in datasheet
sagor
Joined Mar 10, 2019
1,055
It is logic level. While it may start conducting around 1 to 2V, it will not be fully on. Datasheet shows at 4V on gate, what the RDSon really is:
upand_at_them
Joined May 15, 2010
939
I'm curious...I looked in the datasheet, but they do not graph Rds vs Vgs. Is that not something worth knowing?...Since Drain-Source resistance is higher with less Vgs.
38,749
It may be worth knowing, depending upon the application.
But your original question was about the gate-source voltage to fully turn it on.
For that you use the information posted in post #4.
That gives the worst-case values, which is normally what you design to.
35,101
VDS = 50V
ID = 10A @ VGS = 2.7V @ 25°C
ID = 20A @ VGS = 3.1V
ID = 30A @ VGS = 3.5V
ID = 40A @VGS = 3.8V
ID = 50A @ VGS = 4.25V
ID = 70A @ VGS = 5.0V
You can calculate the Drain-Source resistance for each value of VGS.
Edit: The last line has been corrected to 70A instead of 80A.
Dadu@
Joined Feb 4, 2022
155
VDS = 50V
ID = 80A @ VGS = 5.0V
The value of voltage on one axis is showing on the graph but value of current like 10A, 20A, 30A, 40A, 50A, and 80A I don't see on graph
I don't know how do you figure out this current value from graph
35,101
The current scale on the vertical axis is drawn using a log scale.
You will notice that the horizontal lines representing current levels are not evenly spaced.
The lowest line is labeled 10^0. This means 1A.
The next 8 lines are 2, 3, 4, 5, 6, 7, 8, 9A.
The next line is labeled 10^1. This means 10A.
The next 5 lines are 20, 30, 40, 50, 60A.
The top of the chart is 70A.
sagor
Joined Mar 10, 2019
1,055
Math does not add up to datasheet. Datasheet says at 4V Vgs, RDSon resistance is 0.11 ohms (worst case). At 50V Vds, that would give 454A of current. Your graph is for a 20us pulse, not steady state. Hence more confusion....
It would be nice for vendors to show typical graph of Vgs vs RDSon at a fixed voltage (about 1/2 of maximum V breakdown?)...
38,749
If you also notice, that RDSon value is given at a specific drain-source current of 14A.
It would seem obvious that it won't be that low at 454A of current, over 15 times its maximum rating.
And they test with a short pulse so self-heating won't affect the measured value (RDSon increases slightly with temperature).
Does that resolve your confusion?
sagor
Joined Mar 10, 2019
1,055
Somewhat. But, in "normal" use by most hobby people, reading those charts and tables don't exactly match what we are trying to build in terms of values/currents/pulse/etc. Even that 14A rating is for a pulse width < 300us. For a simple on/off MOSFET switch, I guess we have to try and figure out those charts. After that, have to figure RDSon and how much heat we have to dissipate vs trying to turn it fully on. Other than RDSon and maximum continuous current (28A @25C), everything else is an "experiment" in figuring out what to read...
Anyway, reading the datasheet requires one to know how the device is to be used, under what voltage and what load (current)....
dl324
Joined Mar 30, 2015
18,453
Vgs(th) is the voltage at which the device just starts turning on:
A conservative design would use 2V.
The graph in post #9 is for typical devices and, as one infamous member would say, you aren't guaranteed to get a typical device. Though most devices will be typical because the min/max values represent outliers.
Audioguru again
Joined Oct 21, 2019
6,826
They do not print the day of the week on transistors. I think devices with "typical" specs are made of a sunny Wednesday and ones with minimum and maximum specs are made on rainy other days. The phase of the moon has a minor effect on the specs.
Devices that fail the guaranteed specs are thrown in the trash but scavenged and sold on ebay. :D
28,151
The voltages are shown very clearly in post #4
But "fully on" also depends on the current.
That means that the voltage for a specific application depends on the intended on state current.
