I've looked through the IRF710 Datasheet:
http://www.vishay.com/docs/91041/91041.pdf
However, the datasheet does not specify what pin the tab is connected to. I'd like to know this before I finish ordering a heatsink, if it's connected to the drain, I'd need some sort of insulator, correct?
What pin is it connected to internally? Is it floating?
Thank you.
Thank you.
