Ir remote using the arduino
be80be
Joined Jul 5, 2008
2,400
Figured I'd share this works great . First off grab a remote anyone would work next let's install the libraries needed.
https://github.com/cyborg5/IRLib2
Next let's get IR Sensor most any will work i happened to have a 38kHz one laying around.
http://www.vishay.com/docs/82479/tssp58038.pdf
The code to find out what your remote is and list output to a terminal is from .
https://learn.adafruit.com/using-an-infrared-library/hardware-needed
This is there code for finding the key codes and remotes works really good.
Code:
Decoded NEC(1): Value:FF50AF Adrs:0 (32 bits)
The top line gives you the needed values we have NEC and my key press was FF50AF
Code:
#include "IRLibAll.h"
//Create a receiver object to listen on pin 2
IRrecvPCI myReceiver(2);
//Create a decoder object
IRdecode myDecoder;
void setup() {
  Serial.begin(9600);
  delay(2000); while (!Serial); //delay for Leonardo
  myReceiver.enableIRIn(); // Start the receiver
  Serial.println(F("Ready to receive IR signals"));
void loop() {
  //Continue looping until you get a complete signal received
  if (myReceiver.getResults()) {
    myDecoder.decode();           //Decode it
    myDecoder.dumpResults(true);  //Now print results. Use false for less detail
    myReceiver.enableIRIn();      //Restart receiver
The above code finds your keys code which we set in the next code to turn on and off 3 pins of the arduino.
This is code I did to turn on and off with 3 buttons 3 leds the pins could be used for anything you need to control.
Code:
int led1 = 8;
int led2 = 9;
int led3 = 10;
#include <IRLibAll.h>
IRrecv myReceiver(2);//receiver on pin 2
IRdecode myDecoder;//Decoder object
void setup()
  pinMode (led1, OUTPUT);
  pinMode (led2, OUTPUT);
  pinMode (led3, OUTPUT);
  Serial.begin(9600);
void loop() {
    myDecoder.decode();
    if (myDecoder.protocolNum == NEC) {
      switch(myDecoder.value) {
        case 0xFF50AF:  //Volume Down
        Serial.println(F("Volume Down"));
        digitalWrite(led1, !digitalRead(led1));
          break;
        case 0xFFA05F:  //Play/Pause
        Serial.println(F("CH UP"));
        digitalWrite(led2, !digitalRead(led2));
          break;
        case 0xFF7887:  //Volume Up
        Serial.println(F("Volume up"));
       digitalWrite(led3, !digitalRead(led3));
          break;
     myReceiver.enableIRIn(); //Restart the receiver
The circuit
The pins are named pin10 to 8 for the leds, Ground and Vdd for power, And pin2 for the IR output to the arduino.
Here what I put it in a dumptruck im going to down size the uno but it works
