I seem to remember seeing some material which fluoresces in IR light for testing remote controls. I can't find any such thing - did I imagine it?
Every mobile phone and laptop camera has an IR bandstop filter. It’s needed because the sensors have response in the IR and it would swamp the visible light. The difference in sensors and filters, though, means that some can see still see IR very well, some less well, and some almost not at all to the point the visible light in the image renders it invisible.My phone camera doesn't 'see' IR. I seem to remember that they have a filter to remove IR.
For instance: https://www.quora.com/Why-do-manufacturers-put-IR-filters-in-smartphone-cameras
Have you actually done the experiment, or just going by what someone on teh innerwebs said?My phone camera doesn't 'see' IR. I seem to remember that they have a filter to remove IR.
This photo was taken with an iPhone 12 Pro Max. The red arrow points at the IR emitter of a Fluke Bluetooth transceiver. The green arrow points as a diagnostic LED on the circuit board that indicates an IR transmission. I can see nothing at all from the emitter.Have you actually done the experiment, or just going by what someone on teh innerwebs said?
Admittedly my actual experimental evidentiary photo taken yesterday is a best case scenario where the camera is direct on the IR source. If I was just looking for a proof of life from an IR emitter this would be a fine test for zero dollars using equipment I (and many others) already possesses.
I did the experiment and saw nothing - about three inches from the LED.Have you actually done the experiment, or just going by what someone on teh innerwebs said?
Hi A,I did the experiment and saw nothing - about three inches from the LED.
Yes, an IR receiver sees the signal.Hi A,
Stating the obvious, are you convinced that the IR Emitter is actually emitting IR.?
E
i don’t quite understand. Do you mean there is a IR LED mounted in an enclosure pointing to the outside or to the inside?My interest is to be able to track where the IR is going - where the maximum intensity is - for an LED mounted in an enclosure. An IR card would make this easy.
I have used a method in the past where I found a visible light diode (something like blue is good, white less so) that had the same size and optical characteristics then darkened the room and took a photo from the LEDs point of view.Pointing outside through a hole. I would need to make sure the LED and the hole are optimally aligned.
This is my design/build.
by Aaron Carman
by Aaron Carman
by Jake Hertz
