Ionization smoke dedector false alarm problem
bertus
Joined Apr 5, 2008
22,963
I can not read the files.
Probably many on this forum can't read the files.
Post the schematic and PCB as screenshot of the project, if it can not export to an other format.
Bertus
bertus
Joined Apr 5, 2008
22,963
I can see the guardring on the PCB, but I do not see the sensor output.
The sensor output should be within the guardring.
In the datasheet there are schematics with guardrings shown.
Unfortunately they do not show an example PCB layout.
Bertus
Dodgydave
Joined Jun 22, 2012
11,395
Pins 15,16 are Guard Shield pins to prevent false triggering, the detect pin is 14, its probably the PCB design that isn't providing enough shielding.
Personally I would use an Optical design, never keen on Ionasation types....
ilginsarican
Joined Jul 13, 2017
147
Bertus
The sensor output is connected to ion smoke chamber sense pin directly.
The groudn polygon is close to guardrings.I'm worried that this is a problem, but I am not sure :(
ilginsarican
Joined Jul 13, 2017
147
My optical smoke sensor design has worked fortunately.But I have to operate the ion detector.
I doubt about the ground polygon clearance.
