Interpreting the datasheet for a CD4071B OR gate
PJB
Joined Oct 24, 2019
36
I'm just a hobbyist and not a professional.
I would like to know what the meaning is of
the hyphens or dashes in this datasheet and
also the commas and periods.
TIA
PJB.
WBahn
Joined Mar 31, 2012
33,361
Most people find these rather obvious/intuitive.
A hyphen/dash before a number means that it is negative.
A hyphen/dash that is the only thing in a box means that parameter is not supplied.
A comma separates things. So Vin (V) of "0,20" means either 0 V or 20 V. It's also used to separate a description from the symbol that represents it, such as "Input Low Voltage, V_IL Max."
A period is used either as a decimal point, such that 9.95 means 9 + 95/100, or to indicate an abbreviation, such that "Max." is an abbreviation of "Maximum".
Do you understand what a + sign or a - sign means?
35,321
Hyphen before a number means that the value is negative.
Period is the decimal place, for example, -6.8 means negative 6.8
Comma indicates the range of INPUT voltages, for example, 0,5 means LOW input voltage of 0V and HIGH input voltage of 5V.
Dash means that a value for that situation is not applicable or not available.
PJB
Joined Oct 24, 2019
36
Do you mean only two discrete values, either 0V or 20V, or somewhere inbetween ?
