Where in that program you have a problem? Schematic? Block diagram? Code?i want to interface bar code to 89s52 atmel micro controller please help me regarding this program.
sir i am using (i ball bar code) i want this bar code to interface atmel 89s52 micro controller help me regarding interfacing programWhere in that program you have a problem? Schematic? Block diagram? Code?
yesMy isk is on bar code being led bar graph.
USB barcode i am interfacingGet a bar code reader with an output type you both understand and can easily handle, such as RS-232.
Then connect it thru an RS-232 to logic converter to the appropriate place on your micro controller.
i ball bar code from #7 == http://www.iball.co.in/category/Barcode-Scanners/226We are at nine posts and you still have not identified the bar code reader you are using, except to suggest that it has a USB interface. IMHO, since no version of the 89S52 has USB hardware, you will need to find a USB controller to do this interface. I don't think that an 89S52 has the horsepower to bit-bang a USB interface, at least not a full speed (12 MHz.) USB 2.0 compatible connection.
Thanks for the link. It was unclear from Post #7 what the poster was referring to. I thought he was describing a type of bar code since I had never heard of the company or their reader. Poster's should be aware that communicating in textspeak (all lower case letters) has certain manifest disadvantages. If he had said: "I'm using a bar code reader from the "i ball" company that would have been most helpful.i ball bar code from #7 == http://www.iball.co.in/category/Barcode-Scanners/226
At this point I don't think OP using textspeak. I think we are having language problem. If I understand correctly the OP is from India. And while they do use English for education, the quality of English varies greatly. Some individuals are more fluent than others.Thanks for the link. It was unclear from Post #7 what the poster was referring to. I thought he was describing a type of bar code since I had never heard of the company or their reader. Poster's should be aware that communicating in textspeak (all lower case letters) has certain manifest disadvantages. If he had said: "I'm using a bar code reader from the "i ball" company that would have been most helpful.
