Hello All
I m trying to interface EEPROM with 24c04. When i send 2 bytes of data to the EEPROM, the 1st byte gets written to the loaction followed by the 2nd byte overwriting the same loaction. this should not happen . please help me... i have attached my code. plz help
Rich (BB code):
#include <reg51.h>
#include <absacc.h>
#include<string.h>
#include <intrins.h> // for nop operation
void lcdstr(unsigned char *s);
void lcdcmd(unsigned char val);
void lcddata(unsigned char val);
void lcdinit();
unsigned char bdata busyflag;
unsigned char dat,datn;
sbit rs = P2^0;
sbit rw = P2^1;
sbit e = P2^2;
sbit Scl=P3^4; //Serial Clock
sbit Sda=P3^3; //Serial Data
bit aa; // ack
void delay(unsigned int t) // delay function
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<1275;j++);
code unsigned char word1[16]={" program "}; //Line 1 shows the cache
code unsigned char word2[16]={" by Sush"}; //Line 2 shows the cache
code unsigned char arr1[100]={"123456789"};
unsigned char d;
unsigned char a[50];
//////////////////////////////////////start of I2C ////////////////////////////
#define uchar unsigned char
#define uint unsigned int
/*Send start condition*/
void Start(void) /*Initial conditions*/
Scl=1;
Sda=1;
_nop_ ();
_nop_ ();
_nop_ ();
_nop_ ();
Sda=0;
Scl=0;
void Stop(void) /*Stop condition*/
Scl=1;
Sda=0;
_nop_ ();
_nop_ ();
_nop_ ();
_nop_ ();
Sda=1;
Scl=0;
void Ack(void) /*Acknowledge bit*/
Scl=1;
_nop_ ();
_nop_ ();
Scl=0;
void Send(uchar Data) //Subroutine to send data
unsigned char i;
uchar temp;
temp=Data;
for(i=0;i<8;i++)
Sda=temp/128; //extracting MSB
temp=temp<<1; //shiftng the bits towards left one step. the actual MSB is made the LSB
Scl=1;
_nop_();
_nop_();
Scl=0;
aa=Sda; //reading acknowledge
Sda=0;
uchar Read(void) //Read one byte of data, and returns the byte value
unsigned int i;
uchar temp;
Sda=1;
temp=0;
for(i=0;i<8;i++)
temp=temp<<1;
Scl=1;
_nop_();
_nop_();
if(Sda==1)
temp++;
Scl=0;
Sda=0;
return temp; //Returns 8 bit data here
void WrToROM(uchar Data[],uchar Address,uchar Num)//Write a set of data to the AT24C02 in
{ //The first parameter is an array address, data in the AT24C02 in the beginning of the address, number of data
uchar i=0;
uchar *PData;
PData=Data;
Start();
Send(0xa0); //A0, A1, A2 earth, solid AT24C02 write address 0XA0
Ack();
Send(Address);
Ack();
for(i=0;i<Num;i++)
Send(*(PData+i));
Ack();
lcdstr(PData);
Stop();
//void RdFromROM(uchar Address,uchar Num)//Read out in a set of data to the AT24C02
uchar i=0;
uchar *PData;
for(i=0;i<Num;i++)
Start();
Ack();
Send(Address+i);
Ack();
Send(0xa1); //A0, A1, A2 earth, solid AT24C02 read address 0XA1
Ack();
*(PData+i)=Read();
a=*PData;
Scl=0;
Stop();
/////////////////////////////////END of I2C/////////////////////////////////
void lcdinit() // lcd initializations
lcdcmd(0x38);
delay(5);
lcdcmd(0x0c);
delay(5);
lcdcmd(0x01);
delay(5);
lcdcmd(0x06);
delay(5);
void lcdstr(unsigned char *s) // to print a string
unsigned int l,i;
l = strlen(s);
for(i=1;i<=l;i++)
lcddata(*s);
s++;
void lcdcmd(unsigned char val) // command to lcd
P1=val;
rs=0;
rw=0;
e=1;
delay(1);
e=0;
return;
void lcddata(unsigned char val) // lcd data
P1=val;
rs=1;
rw=0;
e=1;
delay(1);
e=0;
return;
void main()
unsigned char leng;
lcdinit();
while(1)
lcdcmd(0x80);
lcdstr(word1);
lcdcmd(0xc0);
lcdstr(word2);
delay(50) ;
lcdcmd(0x01);
leng=strlen(arr1);
WrToROM(arr1,0x00,leng);
lcdcmd(0x80);
lcdstr(arr1);
lcdcmd(0xC0);
RdFromROM(0x00,leng);
delay(50);
lcdstr(a);
delay(50);
lcdcmd(0x01);
delay(50);
