Interfacing Controller and relay
Saiteja chinthalapati
Joined Oct 25, 2018
97
I want to develop a module in which i have to operate 32 relays.
1. Controller ----->Shift Register------>ULN2003------> Relay
but i don't want to use shift register. Can some one suggest me alternate for this. Controller input is DMX-512
ericgibbs
Joined Jan 29, 2010
18,848
hi S,
As a S/Reg is the obvious choice for operating the relays sequentially, why do you not want to use that solution.??
E
Marley
Joined Apr 4, 2016
502
Possibly you misunderstand the purpose of the shift register. In this case it is used as a serial to parallel data converter.
The data is shifted out of the controller on one pin (with another used for the clock). A third pin latches the data out AFTER it is shifted into the register. So the relays all change together (or stay unchanged) - the relay state does not shift.
So there is 32 stage shift register but this is followed by a 32-bit latch that actually holds the relay state. This latch is only updated after the new data is shifted into the shift register.
pmd34
Joined Feb 22, 2014
527
You could have a look at some latches.. such as the 74HC573, these can allow a faster "parallel" type multiplexer interface for switching.
danadak
Joined Mar 10, 2018
4,057
This is a solution for the 32 bit SR register with parallel load, parallel out. Single chip.
In fact most of this chips resources un-used, see right hand window which shows re-
sources used/left. Chip is PSOC 5LP. The load comes from 4 - 8 bit registers internal
that you write before you load the internal 32 bit SR shown below from the registers.
The DMX controller solution could possibly be ported from a PSOC 1 design into this
chip as well.
https://www.cypress.com/documentation/application-notes/an45022-usb-dmx512-converter
http://www.cypress.com/file/103891
The design routed and built fine. The only thing I am unsure about is the cascade
method as datasheet for the SR component (in PSOC a component is an onchip resource) is
incomplete as it is a community designed component using Verilog. So would have to check SO/SI
operation chip to chip. In any event can be made to work. Or the community component could
be modified as a 32 bit component vs the 8 bit as provided, eg. mod the Verilog code.
IDE, PSOC Creator, and compiler free. https://www.cypress.com/products/psoc-creator-integrated-design-environment-ide
Regards, Dana.
danadak
Joined Mar 10, 2018
4,057
A user in PSOC can create custom components, either from a schematic or verilog.
This was done using schematic. Inverter just to test it out. Note very few resources used
in the chip, see right hand window.
Again this is a one chip design.
Regards, Dana.
ElectricSpidey
Joined Dec 2, 2017
2,779
Just a side thought...
If you are driving 32 relays why not use an 8 channel chip instead of 7, unless you want to use the extra channels?
ULN2804A
