This is a nearly trivial task. You break down the waveforms required by the datasheet of the 24C04. Then you pick a couple of port pins on the 89C51 and you make those port pins behave like the pictures in the datasheet. With respect to the timing diagrams you can always go slower but not faster.help!! urgent.... can anybody help me out with th assembly language code for interfacing 89c51 with serial eeprom( 24c04)... pls help me out.. mine is not working.. it is urgen..
thanx...
setb -- set a bit to a 1. This is a read-modify-write instruction
clr -- clear a bit to 0. This is a read-modify-write instruction
nop -- no operation
