Interface LCD to PIC (Details inside!)
jegues
Joined Sep 13, 2010
733
The PIC being used is: PIC16F877A
LCD beind used is:
NHD‐0216XZ‐FSW‐GBW
The objective is to get the LCD to display the following message,
"Bananas $0.49/lb" - for 5 seconds, followed by,
"WOW!" - which is centered on the display and blinking at a rate of once per second for 3 seconds (i.e. 500ms on 500ms off).
I'm having trouble finding information on the correct procedure to use the LCD, and a large portion of the code used in my program has been provided by our instructor.
I have a feeling that before I attempt to, writeString("Hello World!"), to the LCD I must first set the display line and place the cursor accordingly which I don't know how to do. We have been given an incomplete function called setDisplayLine(), but I'm not entirely sure in what sense it is incomplete, nor what the codes being passed to the command function represent.
Then again, I'm not even sure if that is the correct procedure to follow.
Does anyone know?
I've been looking for a data sheet, but all I've been able to find is pinouts which I already have.
See below for my code. (I appologize as the indentation is ruined when I paste it into the forum)
Thanks for the help!
Rich (BB code):
#include <htc.h>
#include <string.h>
#include "ProcessorConfiguration.h"
#include "FunctionPrototypes.h"
#include "Definitions.h"
void main(void){
 portInit();
 LCDInit();
 writeString("Hello World!");
static void interrupt isr(void){
//May be moved to its own .c file later
void LCDInit(void){
 E = 0;
 delay(15); //Wait >15 msec after power is applied
 initCommand(0x30); //command 0x30 = Wake up
 delay(5); //must wait 5ms, busy flag not available
 initCommand(0x30); //command 0x30 = Wake up #2
 delay(160); //must wait 160us, busy flag not available
 initCommand(0x30); //command 0x30 = Wake up #3
 command(0x38); //Function set: 8-bit/2-line
 command(0x10); //Cursor shift mode, S/C to the Left
 command(0x0C); //1DCB: Display ON; Cursor OFF; Blink OFF
 command(0x06); //Entry mode: Inc cursor and display shift off
 clearDisplay();
 returnHome();
void initCommand(char theCommand){ //Cannot Utilize BF
 LCDCOMMAND = theCommand; //put command on PORTD
 RS = RS_COMMAND; // Select Command Register
 RWn = WRITE; // Write Mode
 E = 1;
 E = 0; //Clock enable: falling edge
void command(char theCommand) {
 waitForNotBusy();
 E = 1;
void clearDisplay(void) {
 waitForNotBusy();
 command(0x01); //Clear Display
void returnHome(void) {
 waitForNotBusy();
 command(0x02); //Return Home
void waitForNotBusy(void) {
 unsigned char BF;
 RWn = READ; // Read Mode
 BF = 0b10000000;
 TRISD = 0b11111111;
 delay(1); // Wait at least 80 μs before reading BF
 while(BF==0b10000000){
  E = 1;
  BF = LCDDATA & 0b10000000;
 TRISD = 0b00000000;
void delay(unsigned char loops) {
 unsigned char i;
 for(i=0; i<loops;i++){}
//End of block pasted from LCDInitialization.c
void setDisplayLine(unsigned char line, unsigned char position) { //This function is incomplete.
 switch(line) {
  case 1:command(0b01000000);
  break;
  case 2:command(0b11000000);
  break;
void writeChar(char theData) {
 waitForNotBusy();
 LCDDATA = theData; //put data on PORTD
 RS = RS_DATA; // Select Data Register
 E = 1; //enable pulse width >= 300ns
void writeString(char *theString) {
 unsigned char i;
 for(i = 0; i < strlen(theString); i++) {
  waitForNotBusy();
  LCDDATA = theString; // Put data on PORTD
  E = 1; // Enable pulse width >= 300ns
  E = 0; // Clock enable: falling edge
And the code for portInit(),
Rich (BB code):
#include <htc.h>
void portInit(void){
//Configure for Digital IO
PCFG3 = 0;
PCFG2 = 1;
PCFG1 = 1;
TRISE0 = 0;
TRISE1 = 0;
TRISE2 = 0;
TRISD = 0b00000000; //Configure PORTD for output
INTCON = 0; //Disable interrupts.
spinnaker
Joined Oct 29, 2009
7,830
Sounds to me like someone wants us to do his / her homework for him or her. :)
Do a search on HD44780. You will find datasheets and plenty of code samples . But you should really work from the datasheet just like your instructor wants you to. :)
jegues
Joined Sep 13, 2010
733
Where in my original post did I ever ask anyone to do my homework for me?
As the description of this section of the forum reads,
"Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming."
I would like to get some help, not have someone do my homework for me. Just thought I would clarify that for you.
Anyways, I've already looked up the data sheet online,
http://www.newhavendisplay.com/specs/NHD-0216XZ-FSW-GBW.pdf
I feel like I understand the majority of the information being presented, aside from the font table on page 6.
What is CGRAM?
It also shows example intialization programs, but not how to actually display anything on the LCD? Can anyone point me in the right direction?
Thanks again!
spinnaker
Joined Oct 29, 2009
7,830
What is CGRAM?
Thanks again!
Page 6 is just a really complicated looking ASCII table.
http://www.asciitable.com/
CG RAM = Character Generator RAM
DD RAM = Display Data RAM
You are probably going to want to use 4 bit display. It is more complicated but uses less pins. Check page 8. It shows how to display a character using 4 bit.
You will still need to know how to display it on the line you want but that is next.
Remember timing is fairly critical for these displays. It does not need to be exact but you need to pay attention to the delays they recommend.
jegues
Joined Sep 13, 2010
733
OK then page 7 has the code to output a character for 8 bit.
I already have a similiar code within a function called writeChar.
See the code below,
Rich (BB code):
 waitForNotBusy();
However, when I call the function in main like so,
writeChar("p");
I don't see any display on the LCD.
Do I have to set the display first somehow?
spinnaker
Joined Oct 29, 2009
7,830
Did you run the initialization code?
Post your schematic of how you have the LCD wired.
Do you have a scope, logic probe pr even a multimeter?
Step through your code. When you out put a byte to the port, verify it is appearing at the LCD how you expect it to be. This includes your enable, r/w and select bits.
Sometimes it is easier just to write a little test program to toggle the bits on your LCD and forget about the LCD code till you confirm all of your connections.
t06afre
Joined May 11, 2009
5,934
You do know what Hi-Tech C is shipped with examples. And that also include a LCD demo. Look in the the "C:\Program Files\HI-TECH Software\PICC\9.83\samples" folder. It is a four bit LCD demo. But it can with ease be modified to 8 bit. Your code is somewhat untidy. Like Hi-Tech are shipped with good functions for delays. They are named "__delay_ms()" and "__delay_us()" In order to work they need a
Rich (BB code):
#define _XTAL_FREQ 4000000
In the example the system clock is 4 MHz. I also noticed that as far as I can see you do not set the configurations word.
Why not use the HI-Tech C example as your work horse. And take it from there. As a hint make a copy of the example. So you do not overwrite it
John P
Joined Oct 14, 2008
2,025
What the???
Rich (BB code):
void LCDInit(void){
 E = 0;
How come delay(5) counts 5 milliseconds but delay(160) counts 160 microseconds?
spinnaker
Joined Oct 29, 2009
7,830
Not sure. Check your documentation for delay. Where is it from BTW? Which compiler?
It could be that delay has a maximum count it can handle. Try stringing a bunch together. Say 3 50s and a 10.
jegues
Joined Sep 13, 2010
733
What the???
Rich (BB code):
void LCDInit(void){
 E = 0;
That is a typo, its actually 160ms which is larger than 160us so it is sufficient.
HI-TECH C compiler.
spinnaker
Joined Oct 29, 2009
7,830
Check your datasheet. Is there an on-board current limiting resistor for the back light? If not you should add one.
What is the value of that trim pot?
jegues
Joined Sep 13, 2010
733
I'm not sure of its exact value, but isn't that just for adjusting the intensity of the backlight?
t06afre
Joined May 11, 2009
5,934
@jegues
You are using HI-Tech C correct? And which version are you using. Any deatils on that. The configuration word(s) are described in the section SPECIAL FEATURES OF THE CPU in the datasheet. I may give you some pointers if I know which version you are using of the C compiler. The configuration word can be set from MPLAB. But it is highly recommended that you put this information in the code.
jegues
Joined Sep 13, 2010
733
@jegues
Yes I am using HI-TECH C. The version listed in the readme file is,
"HI-TECH C Compiler for PIC10/12/16 MCUs Version 9.83 ".
t06afre
Joined May 11, 2009
5,934
At the top of your PIC header file located in "......\HI-TECH Software\PICC\9.83\include" you will find this section
Rich (BB code):
// Configuration mask definitions
// Config Register: CONFIG
#define CONFIG               0x2007
// Oscillator Selection bits
// RC oscillator
#define FOSC_EXTRC           0xFFFF
// HS oscillator
#define FOSC_HS              0xFFFE
// XT oscillator
#define FOSC_XT              0xFFFD
// LP oscillator
#define FOSC_LP              0xFFFC
// Watchdog Timer Enable bit
// WDT enabled
#define WDTE_ON              0xFFFF
// WDT disabled
#define WDTE_OFF             0xFFFB
// Power-up Timer Enable bit
// PWRT disabled
#define PWRTE_OFF            0xFFFF
// PWRT enabled
#define PWRTE_ON             0xFFF7
// Brown-out Reset Enable bit
// BOR enabled
#define BOREN_ON             0xFFFF
// BOR disabled
#define BOREN_OFF            0xFFBF
// Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit
// RB3/PGM pin has PGM function; low-voltage programming enabled
#define LVP_ON               0xFFFF
// RB3 is digital I/O, HV on MCLR must be used for programming
#define LVP_OFF              0xFF7F
// Data EEPROM Memory Code Protection bit
// Data EEPROM code protection off
#define CPD_OFF              0xFFFF
// Data EEPROM code-protected
#define CPD_ON               0xFEFF
// Flash Program Memory Write Enable bits
// Write protection off; all program memory may be written to by EECON control
#define WRT_OFF              0xFFFF
// 0000h to 00FFh write-protected; 0100h to 1FFFh may be written to by EECON control
#define WRT_256              0xFDFF
// 0000h to 07FFh write-protected; 0800h to 1FFFh may be written to by EECON control
#define WRT_1FOURTH          0xFBFF
// 0000h to 0FFFh write-protected; 1000h to 1FFFh may be written to by EECON control
#define WRT_HALF             0xF9FF
// In-Circuit Debugger Mode bit
// In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins
#define DEBUG_OFF            0xFFFF
// In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger
#define DEBUG_ON             0xF7FF
// Flash Program Memory Code Protection bit
// Code protection off
#define CP_OFF               0xFFFF
// All program memory code-protected
#define CP_ON                0xDFFF
Then match these options to the figure named "REGISTER 14-1: CONFIGURATION WORD (ADDRESS 2007h)" in the PIC datasheet
At the top of your program after the include section. You add the __CONFIG() macro. You will be using RC OSC, and watchdog timer can be turned off. So to get you started the two first parameters in your __config macro will be like this. You can do the rest. The order of the macro names is unconcerned. For more info see the HI-Tech C manual section 3.3.4 Configuration Bit Access in the docs folder.
Rich (BB code):
__config(FOSC_EXTRC & WDTE_OFF........)
As you see the macro names are bitwise ANDed together to form the configuration value. To avoid any confusion or problems set every options up to the last CP_OFF/CP_ON option. (CP_OFF in your case)
ErnieM
Joined Apr 24, 2011
8,377
On the display Pins 15 and 16 are the backlight LED and absolutely need a limit resistor. If you powered on like that you probably killed the LED but the unit should still work in a bright room. The pot connecting to Pin 3 should typically be 10K. If misadjusted nothing will show on the display. Turn it one end to the other to find where it wants to be.
The config word needs to be set. The following may work with your hardware:
Rich (BB code):
// Oscillator Selection bits: RC oscillator
// Watchdog Timer Enable bit: WDT disabled
// Power-up Timer Enable bit: PWRT disabled
// Brown-out Reset Enable bit: BOR disabled
// Low-Voltage (Single-Supply) ICSP Enable bit: RB3 is I/O, HV on MCLR for programming
// Data EEPROM Memory Code Protection bit: Data EEPROM code protection off
// Flash Program Memory Write Enable bits: Write protection off; all program memory may be written to by EECON control
// In-Circuit Debugger Mode bit: In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger
// Flash Program Memory Code Protection bit: Code protection off
__CONFIG(FOSC_EXTRC & WDTE_OFF & PWRTE_OFF & BOREN_OFF & LVP_OFF & CPD_OFF & WRT_OFF & DEBUG_ON & CP_OFF);
