Hello everyone.
I am a bit stuck with one task and i need help.
I am trying to read input from keypad and display it on the display.
I first wrote the program code which reads the input from the keyboard and tested it with LEDs and it works
well.
Then I wrote code that prints text to display with no input from the keyboard and then tested it and it also
works well.
But when I put together whole code it does not work as it should.
I am new in programming of embedded systems and i know
that my code is not the best and that probably has a lot of mistakes but I try to do the best they can.
Here is my code
well.
works well.
Here is my code
Rich (BB code):
#define F_CPU 8000000UL
#include <avr/io.h>
#include <stdio.h>
#include <util/delay.h>
#define RS 0 //pin nr in port
#define RW 1 //pin nr in port
#define E 2 //pin nr in port
FILE *myFile;
void write_LCD(unsigned char data, FILE *stream);
int get_char(FILE *stream);
void write_instruction(unsigned char data);
void init_LCD(void);
void delay8us(void);
void delay8us(void) {
volatile unsigned char x;
for(x=0;x<5;x++);
void test_if_busy(void) {
unsigned char x;
PORTC &=~(1<<RS);
PORTC |= (1<<RW);
DDRB &=~(1<<7); // input
PORTB &=~(1<<7); // remove pullup
do {
PORTC |= (1<<E);
delay8us();
x = (PINB & 0x80); // read high nibble
PORTC &=~(1<<E);
PORTC |= (1<<E);
PORTC &=~(1<<E); // read low nibble
while(x);
DDRB |= (1<<7); // output
void write_LCD(unsigned char data, FILE *stream) {
char x;
PORTB = (data & 0xf0); //high nibble
PORTC &=~(1<<RW);
PORTC |= (1<<RS);
PORTC |= (1<<E);
PORTC &=~(1<<E);
x = (data<<4);
_delay_ms(65);
PORTB = x; //low nibble
PORTC &=~(1<<RW);
PORTC |=(1<<RS);
PORTC |=(1<<E);
PORTC &=~(1<<E);
test_if_busy();
char get_key(void)
volatile char button;
volatile char position;
button = PINB;
if (button == 0b01111011)
position = 49;
else if (button == 0b01111101)
position = 50;
else if (button == 0b01111110)
position = 51;
else if (button == 0b10111011)
position = 52;
else if ( button == 0b10111101)
position = 53;
else if ( button == 0b10111110)
position = 54;
else if ( button == 0b11011011)
position = 55;
else if ( button == 0b11011101)
position = 56;
else if ( button == 0b11011110)
position = 57;
else if ( button == 0b11101011)
position = 8;
position = 48;
else if ( button == 0b11101101)
position = 13;
else if ( button == 0b11101110)
position = 68;
else if (button == 0b11101111)
position = 5;
return position;
int get_char(FILE *stream){
char c;
volatile char column;
volatile char row;
do{
row = 0b01111111; // send 0 to first row
for (int i = 0; i<2; i++){
PORTB = row;
column = PINB; // read input from keypad
for(int i = 0, a = 64; i<5; i++){ // check all 4 rows
if(column == row)// if key is not pressed in first row
row = column + a; // check next row
for(int j = 0; j < 2; j++){
PORTB = row;
column = PINB;
i++;
a = a/2;
else
c = get_key();
c = get_key();
}while(column == 0b11101111); // if neither key is not pressed repeat loop
write_LCD(c, stream);
return (int)c;
void write_instruction(unsigned char data) {
unsigned char x;
PORTC &=~(1<<RW);
PORTC &=~(1<<RS);
PORTC |= (1<<E);
PORTC &=~(1<<E);
x = (data<<4);
PORTB = x;
PORTC &=~(1<<RW);
PORTC &=~(1<<RS);
PORTC |= (1<<E);
PORTC &=~(1<<E);
test_if_busy();
void set4bitmode() {
_delay_ms(65);
PORTB = (0x20 & 0xf0);
PORTC &=~(1<<RW);
PORTC &=~(1<<RS);
PORTC |= (1<<E);
PORTC &=~(1<<E);
void init_LCD(void) {
unsigned char x;
for(x= 0;x<5;x++) {
_delay_ms(65);
PORTB = 0; //all low
PORTC &=~(1<<RS);
PORTC &=~(1<<RW);
PORTC &=~(1<<E);
DDRB = 0xF0; // all output
PORTB = 0x0F;
DDRC |= (1<<RS);
DDRC |= (1<<RW);
DDRC |= (1<<E);
_delay_ms(65);
set4bitmode(); // 4 bit interface
for(x=0;x<3;x++) {
write_instruction(0x28);
_delay_ms(65);
write_instruction(0x0F);
write_instruction(6);
write_instruction(1);
int main(void)
char teck;
init_LCD();
write_instruction(1); // clear display
myFile = fdevopen(write_LCD, get_char);
while(1){
scanf("%c", &teck);
printf("%d",teck);
