integration
studiot
Joined Nov 9, 2007
4,998
Well your next step should be to create two integrals.
Have you done this
Then it looks like a gamma function transformation integral to me, although there are (as always) other ways.
What methods have you been taught for trig functions?
edit presumably there should be a 'dt' in there somewhere?
32,973
Can you integrate
\int{u dt}
or
\int{u^2 dt}
If so, then you are done since those are the forms you have. You just need to substitute 'u' for something in order to make it apparent.
Note that I'm just looking at your last line. Your handwriting is too sloppy for me to be sure that I can make out your earlier stuff.
micro1
Joined Feb 22, 2015
79
Can you integrate
\int{u dt}
or
\int{u^2 dt}
respect your phrasing
studiot
Joined Nov 9, 2007
4,998
I can't see how you get from line 1 to line 2 in your original post.
There should be six terms in line2, not two terms.
So before you go of down some substitution route get the leadup correct.
32,973
What makes you think I don't have respect for my phrasing?
But let's try this: Your otherwise perfect penpersonship has been corrupted, through no fault of your own of course, by the pen, the paper, the camera, and the internet so as to make it less than optimally readable to us inferior beings.
32,973
Could you post what you think his first line is? I can't make a good portion of it. I'm guessing the TS will be offended if I ask him to present his work more clearly.
Like you, I don't see how the first line leads to the second, but I can't make all of that out clearly, either. It would also appear that there's a sign error in going from the second to the third, assuming that that's a plus sign between the two terms on the second line.
studiot
Joined Nov 9, 2007
4,998
Best I can do
\(\int\limits_0^{2\pi } {\left( {72\cos t\sin t - 72\sin t + 41} \right)} \bullet \left( { - 2\sin t + 2\cos t} \right)dt\)
edit corrected first bracket
32,973
Best I can do
\(\int\limits_0^{2\pi } {\left( {72(\cos t\sin t - 72\sin t + 41)} \right)} \bullet \left( { - 2\sin t + 2\cos t} \right)dt\)
That helps. I would have never guessed that was a '41' due to what is just to the right of the '1'. I couldn't tell if that was a 'k', perhaps? It also looks like there is an 'i'-hat unit vector on the first term and maybe on the second term. Or maybe that's a 'j'-hat. Oh, wait a minute, my guess is that this is
\(\int\limits_0^{2\pi } \left[ {72\cos(t)\sin(t) \hat{i} - 72\sin(t) \hat{j} + 4 \hat{k}} \right] \cdot \left[ - 2\sin(t) + 2\cos(t) \right] dt
If so, the TS is making a total hash of things.
So now I'm guessing that what looks like "1uH" or perhaps "1HH" on the second and third lines is actually supposed to be "144".
